OhChit Posted July 23, 2005 Share Posted July 23, 2005 On a Subaru 2.2 or 2.5 N.A. under normal hot weather driving what should the water temps run at in Fahrenheit’s, what is normal operating temp range ? Also what is the correct temp thermostat to use? I'm considering converting to a Turbo. Do Turbo’s run hotter, if so at what temps? Thanks Link to comment Share on other sites More sharing options...
blitz Posted July 23, 2005 Share Posted July 23, 2005 The factory thermo is labeled: 78*C, which is 172*F. Most folks that run a performance setup use the Zerosports 71*C / 160*F aftermarket unit. The Zerosports is a real Fuji (FHI) part which is an important distinction. DON'T use anything except a Fuji part. Subaru cooling systems place the thermo at the water inlet as opposed to the outlet like most other arrangements. I'm not sure why, so I'll just assume it's a better way to do it. Maybe someone else can chime in as to why ...I'm curious. Link to comment Share on other sites More sharing options...
OhChit Posted July 23, 2005 Author Share Posted July 23, 2005 The factory thermo is labeled: 78*C, which is 172*F. Most folks that run a performance setup use the Zerosports 71*C / 160*F aftermarket unit. The Zerosports is a real Fuji (FHI) part which is an important distinction. DON'T use anything except a Fuji part. Subaru cooling systems place the thermo at the water inlet as opposed to the outlet like most other arrangements. I'm not sure why, so I'll just assume it's a better way to do it. Maybe someone else can chime in as to why ...I'm curious. But what is the normal engine operating temp for a 2.2 or 2.5. Is 190-200 normal for hot weather driving? Link to comment Share on other sites More sharing options...
Cougar Posted July 23, 2005 Share Posted July 23, 2005 Those temps sound about normal to me. Link to comment Share on other sites More sharing options...
blitz Posted July 23, 2005 Share Posted July 23, 2005 But what is the normal engine operating temp for a 2.2 or 2.5. Is 190-200 normal for hot weather driving? I've never measured it, so I don't really know, but here's some book data: My '02 2.5 manual lists normal discharge temp as 185*F. It lists beginning-to-open thermo temp as 173*F, and full-open temp as 196*F for both turbo & non-turbo. It indicates primary fan on-temp as 203*F for the non-turbo and 205*F for the turbo. That should at least give you some indication of the range where Subaru is trying to keep the coolant temp. A turbo motor of a given displacement will generate more thermal energy than an identical displacement N/A motor since it's burning more fuel and air, so the radiator ideally should be of a larger capacity. Link to comment Share on other sites More sharing options...
