TheSubaruJunkie Posted July 25, 2005 Share Posted July 25, 2005 Taking the wagon on its last road trip to the sky... I plan on hauling my '84 Wagon with a 3" lift to Reno where me and Jibs will transform her into a new off-roading subaru. Problem is, my ignition is broke on the wagon and right now the key is stuck "on" so the steering wheel will not lock. Would this cause problems while towing it on the dolly? I would feel better if the steering would lock, but since it wont im not sure if I should just opt for the car trailer and scratch the dolly. Any suggestions? -Brian Quote Link to comment Share on other sites More sharing options...
mcbrat Posted July 25, 2005 Share Posted July 25, 2005 I towed a lifted turbo brat 5 hours on a tow dolly, and the steering wheel wasn't locked.... but I can see where you'd be concerned... double pivot point..... Quote Link to comment Share on other sites More sharing options...
NorthWet Posted July 25, 2005 Share Posted July 25, 2005 Well, since the wheel doesn't lock straight ahead, I don't like locking the wheel in the first place. (That, and the abuse on the column lock mechanism.) Use tie-downs to the steering wheel both sides, and find suitable attachment points near the doors. Quote Link to comment Share on other sites More sharing options...
themixtoo Posted July 25, 2005 Share Posted July 25, 2005 Taking the wagon on its last road trip to the sky... I plan on hauling my '84 Wagon with a 3" lift to Reno where me and Jibs will transform her into a new off-roading subaru. Problem is, my ignition is broke on the wagon and right now the key is stuck "on" so the steering wheel will not lock. Would this cause problems while towing it on the dolly? I would feel better if the steering would lock, but since it wont im not sure if I should just opt for the car trailer and scratch the dolly. Any suggestions? -Brian This all depends on whether you put it on the dolley with the front wheels up or the rear wheels up. If you put the front wheels up and manual tranny in neutral you just need to strap the front wheels to the dolley (this is standard procedure) steering wheel does not have to be locked. If you back it on the dolley (rear wheels up) then you will have to lock the steering wheel somehow. Then again, the safest way is front wheels up and remove the driveshaft (that's how I use the dolley with my AWD 'Ru's) actually I just disconnect the driveshaft and wire it up out of the way so it never lets any fluid out of the tailshaft of the tranny. Gary Quote Link to comment Share on other sites More sharing options...
soobmater Posted July 25, 2005 Share Posted July 25, 2005 well what northwet said is very good.the stering whell locks as you turn it and then your tires are turned. i assume you are goin to pull it onto the dolly and not back it up on it right? you should be fine brian Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 25, 2005 Share Posted July 25, 2005 dont make wide turns, and especially dont back up with a loaded dolly! towed unlocked it does good, just dont try to exercise subaru turning radius with the rig. pretend you are driving something ill built with no turning raduis Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 26, 2005 Author Share Posted July 26, 2005 I rent these dollys daily to newbs and i know how to use/operate/safely tow vehicles. Just didnt want my car fishtailing or something cause of the steering being unlocked. and yes, i plan to have the front tires on the dolly. That way i can set the parking brake and be absolutly sure the car wont come off. That and it will have safety chains around the tow points, along with the straps. And mick... it'd actually be a tripple pivot point. The tow hitch is one, the swivel on the dolly is another and then the car turning... would be three, no way in hell im gonna try backing that thing up. -Brian Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted July 26, 2005 Share Posted July 26, 2005 the front wheels need to be able to turn, at least that's what the screw-haul guy told me last time I rented a dolly (I prefer the trailers..) Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 26, 2005 Author Share Posted July 26, 2005 I'd get a trailer from work and just skip the dolly, but after I drop the wagon off we need to use the dolly to get a brat back to Jibs. The Brat wont start, and I dont feel like pushing it onto a trailer, would be easier to push it onto a dolly. -Brian Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 26, 2005 Share Posted July 26, 2005 try parallel parking a dolly it can be done! then do it un loaded:) Quote Link to comment Share on other sites More sharing options...
TomRhere Posted July 26, 2005 Share Posted July 26, 2005 I've towed many a vehicle using tow-dolly, and have always had the steering wheel un-locked. Helps with making tight turns in the City, and I've never had any fish-tailing problems doing so. It is actually recommended to leave wheel un-locked to lessen chance of damage to steering system. As for getting the non-running BRAT up on the dolly; Block the back of the rear tires, lift front wheels off the ground by placing a small jack under the engine cross-member, go as high as jack will allow. Back tow-dolly under vehicle, best to align dolly with front tires by hand, then hook it to tow vehicle. Dolly will lift vehicle off of jack as the tires roll up the ramps. That's how I got the dead XT-6 that Miles and I bought up on the dolly, and have done afew others since then. Ain't easy pushing a vehicle up onto dolly by hand, been there done that. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted July 26, 2005 Share Posted July 26, 2005 I rent these dollys daily to newbs and i know how to use/operate/safely tow vehicles. Just didnt want my car fishtailing or something cause of the steering being unlocked. and yes, i plan to have the front tires on the dolly. That way i can set the parking brake and be absolutly sure the car wont come off. That and it will have safety chains around the tow points, along with the straps. And mick... it'd actually be a tripple pivot point. The tow hitch is one, the swivel on the dolly is another and then the car turning... would be three, no way in hell im gonna try backing that thing up. -Brian If your front tires are STRAPPED down to a dolly that pivots... don't you think that your tires would need to be able to turn with the pivoting action? Anyway. As long as your tires are strapped to the dolly properly you don't need your wheel locked and it's preferred you have it unlocked. This will help your vehicle to track better. You don't need your parking brake on either. I know it will help you feel better.. but it wont make a difference. Quote Link to comment Share on other sites More sharing options...
