oddcomp Posted July 25, 2005 Share Posted July 25, 2005 so um yeah this is the beast i been arguing with for a long time to get together one 1985 suby rx clicky here for pic with this hiding under the hood "clicky again" whats in the picture? ford edis coil pack <yay no disty> 8.8 mm accel spiral core plug wires chevy alternator ford thunderbird intercooler maserati bi turbo intercooler piping <the chrome pipes> dodge turbo minivan intercooler rubber hose stuff off the wife's van..shhhhh blue silly cone diesel radiator hose ssqv blow off valve <added a second bov from the minivan before the intercooler> since it seems my ssqv does not like to vent below 2-3 psi plus since the dodge one hangs open it allows the turbo to kinda prespool <little to no resistance against the turbo with the bov hanging open > and yes.. its sposed to hang open i am skipping the apc in this setup i think and just going straight to letting the megasquirt run the boost / knock sensing since i asked for some code mods to be done that makes the ms work just like the apc but with more features i still have to build my knock sense cicuit for the ms to run ignition/boost management in the event of detonation problems <bad gas to much boost to much advance ect ect> for a idea of what all the new code for the ms box can do go clicky here so whats next to do?? well fix my wasted shifter bushing <the hardest ones to change of course> change out my exhaust get rid of the craptastic stock setup fix bent strut build my liquid c0-2 intercooler sprayer and then go from there oops forgot thanks noah for the pic thanks to jason,shadow,northwet,garner,lstintexas for all the help Link to comment Share on other sites More sharing options...
WJM Posted July 25, 2005 Share Posted July 25, 2005 coolness. Hey...MS has LAUNCH CONTROL! hmmm...Anti-Lag is next? Link to comment Share on other sites More sharing options...
Gravityman Posted July 25, 2005 Share Posted July 25, 2005 Hey oddcomp thats a nice setup you got there! Just wondering, what did you do with the disty did you remove it or just leave it in there? Link to comment Share on other sites More sharing options...
NorthWet Posted July 25, 2005 Share Posted July 25, 2005 Hey oddcomp thats a nice setup you got there! Just wondering, what did you do with the disty did you remove it or just leave it in there? As of WCSS7, he still had the distributor in place, as he hadn't yet gotten a block-off plate for the dist mount hole. Oddcomp, get all of this stuff worked out, as I WANT it for my uber-Twagon. Link to comment Share on other sites More sharing options...
Gravityman Posted July 26, 2005 Share Posted July 26, 2005 As of WCSS7, he still had the distributor in place, as he hadn't yet gotten a block-off plate for the dist mount hole. Oddcomp, get all of this stuff worked out, as I WANT it for my uber-Twagon. Correct me if I am wrong but the EA81/82/ER27's dont use the disty for any other purpose other then for the spark correct. I am about 99.99999% sure this is true but i just want to make sure 100%. Link to comment Share on other sites More sharing options...
subyrally Posted July 26, 2005 Share Posted July 26, 2005 dude, you gotta make me a ms'n'edis setup. and in a stock set up, the ditsy also controls fuel doesnt it. im liking the lack of the maf in that pic. nice, map sensors are much better than maf's any way. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 26, 2005 Share Posted July 26, 2005 I wanted to drive your car in comparison. You still running stock boost on that bad mammajamma?? Sweet car indeed. -Brian Link to comment Share on other sites More sharing options...
oddcomp Posted July 26, 2005 Author Share Posted July 26, 2005 well in the stock setup the disty does 2 things provides spark.. duh lol secondly the tach signal off the - side of the coil runs to the ecu and also triggers the fuel injections pulses each rpm signal causes all 4 injectors to fire in the stock ecu so 1 rpm = 1 injection event and yea i can build it pm me again.. or message me on instant message type thing just put my better downpipe on till i make a even better one Link to comment Share on other sites More sharing options...
Gravityman Posted July 26, 2005 Share Posted July 26, 2005 Thanks comp & subyrally. Hey is that one of those all metal mesh intakes, or does it have a fabric filter element? I saw one at advanceauto but I never really looked into them to see how well they perform with HP gains and filtration properties. Link to comment Share on other sites More sharing options...
gravelRX Posted July 26, 2005 Share Posted July 26, 2005 Glad to see it running. I have been following your progress and I have to say Good Job to you. The true heart of grassroots engineering. Any idiot can buy a fast car. Let's see them build one. Jay Link to comment Share on other sites More sharing options...
subyrally Posted July 26, 2005 Share Posted July 26, 2005 i currently work at advance auto, some of the filters we sell are crap, like the apc cones, they arent that good, i havent messed with the mushroom filter by apc. i have used the metal mesh filter that is made by apc, under their high end name. it isnt that bad of a filter, but i would still reccomend a k&n filter over most everything else. then ther is the regular paper filters, they may keep your engine clean,but they sap a lot of power. hey odd, ill hit you up later, i need to figure out how long its going to take me to get to the point that ill need that set up, but i still want one so bad it hurts. Link to comment Share on other sites More sharing options...
oddcomp Posted July 26, 2005 Author Share Posted July 26, 2005 well.. junky my boy you should have said something.. actually i looked around for you to take you for a ride. but you was always bizzy b.s.ing with someone as far as my filter goes its 20 dollar knock off but it is in fact a cotton fiber cleanable element yay but the metal "mesh" you see if to reinforce the element so it does not collapse and yes stock boost so far was gonna pop my apc back in wire it all up but then .. i realized i would be taking it back out soon to wire up the megasquirt boost circuit so i figured.. eh why do things twice. and besides.. at stock boost it moves well enough yes any one who can afford it can buy a fast car and slap aftermarket parts on it but half the fun not to mention being proud of your car comes from being able to say.. yeah i built those parts ect i did not build it to be fast<ok well sorta> i built it to prove i could mostly to myself still at half an exhaust swap.. got owned by my dead sawzall so i couldnot cut the old muffler off . so bigger dp ending in open exhaust right around the middle of the car .. Link to comment Share on other sites More sharing options...
nkx Posted July 26, 2005 Share Posted July 26, 2005 so bigger dp ending in open exhaust right around the middle of the car.. sounds done to me! good job on the install too! i might have to use some of that diesel radiator hose too, looks easier to use than hardpipes & expensive silicon couplers. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 26, 2005 Share Posted July 26, 2005 well.. junky my boy you should have said something.. actually i looked around for you to take you for a ride. but you was always bizzy b.s.ing with someone Man i looked for you to B.S. with and finally caught up to you when you were putting dry ice on the intercooler. I was gonna ask then but it was getting dark and there was alot of people around admiring (me being one of them). Anyhow, there's always next year and I hope its still running then -Brian Link to comment Share on other sites More sharing options...
oddcomp Posted July 26, 2005 Author Share Posted July 26, 2005 well by next year since i can actually tune for it i hopefully will have a high compession turbo motor i suspect thats why previous attempts at hi comp turbo ea82t's don't live long is the lack for proper fueling/ignition that the stock ecu can not compensate for not that mine lacks low end power hehe but still eh gotta try that diesel radiator hose i bought .. was like 1.something dollar per inch! but it is semi flexible and it works great infact i still have a section of it left thats about 5-8 inch's long and 2.5" diameter fits perfect over suby throttle body's Link to comment Share on other sites More sharing options...
avatar382 Posted July 26, 2005 Share Posted July 26, 2005 Nice job!! How much powar? Link to comment Share on other sites More sharing options...
oddcomp Posted July 26, 2005 Author Share Posted July 26, 2005 good question .. who knows.. need to scrape up money for a dyno run down in portland Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 26, 2005 Share Posted July 26, 2005 heh, that motor looks a little familiar... last time I saw it, it was in a turbowagon with a 4EAT behind it IIRC. Dude wanna build me some MS&EDIS goodies for my fantasticly big and expensive pile of crap in my driveway? I have a donor car for the parts needed for the EDIS but I'm so incredibly computer stupid its not even funny... Link to comment Share on other sites More sharing options...
oddcomp Posted July 27, 2005 Author Share Posted July 27, 2005 actually.. it was a 3at.. and at that time i was not intercooled and did not have the spider intake on the motor either but yeah.. same motor 230k mile motor with all that dropped into a 152k mile rx body haha seems to run a tad warm <like 210f> on the freeway with a 180 thermostat but runs cool around town i suspect i need to flush my cooling system Link to comment Share on other sites More sharing options...
