Meeky Moose Posted July 26, 2005 Share Posted July 26, 2005 ok, i put my webered ea82 into another wagon today, another friend did most of the rear disc conversion, we got it running.. heres the problem, with the weber the ac compressor will not bolt up to the mounting brackets.. its hitting the carb. what do i need to do to basically swap places with the alternator and ac compressor? i know some soobs had the ac compressor on the far side of the engine next to the battery.. with my brackets, my ac compressor is next to the carb and the alternator is closest to the battery.. i need to swap those to get it to fit.. anyone ever had this problem? how'd you fix it? etc.. the new wagon is an 86' gl without power steering. Link to comment Share on other sites More sharing options...
Meeky Moose Posted July 26, 2005 Author Share Posted July 26, 2005 bump, still need help :/ Link to comment Share on other sites More sharing options...
mcbrat Posted July 26, 2005 Share Posted July 26, 2005 I thought on ea82,s you needed to turn the weber 180 deg to get it to fit with the other accessories... if you raised the weber up some, would it fit? I had to use 2 .5" spacers to get above the disty with this carb... http://www.ultimatesubaru.org/80s/mick/gallery/holley3.jpg Link to comment Share on other sites More sharing options...
Meeky Moose Posted July 26, 2005 Author Share Posted July 26, 2005 well, if i turn the carb 180, then i run into the throttle cable problem... the part of the weber that is in the way of the ac compressor is the float bowl/fuel intake line.. as it is now the hood barely closes, lol has like 1/2" clearance between the hood and the air filter. so i can't space it.. Link to comment Share on other sites More sharing options...
Tom63050 Posted July 26, 2005 Share Posted July 26, 2005 well, if i turn the carb 180, then i run into the throttle cable problem... the part of the weber that is in the way of the ac compressor is the float bowl/fuel intake line.. as it is now the hood barely closes, lol has like 1/2" clearance between the hood and the air filter. so i can't space it.. 1. If you have the taller air filter, you could buy the short one. Or, 2. Reverse the carb anyway and deal with the throttle cable issue. It is doable. Link to comment Share on other sites More sharing options...
subynut Posted July 26, 2005 Share Posted July 26, 2005 Mine was real close when I had the Weber on mine. It was tight, but it fits. I also had two spacers under the carb, that might have been why. Link to comment Share on other sites More sharing options...
