northguy Posted July 26, 2005 Share Posted July 26, 2005 With winter looming (it always is here), I'm thinking about options to create a bit more ground clearance with the xt6. I don't want to be plowing snow with the underside of it and would hope to have at least 6' of clearance, preferably more. It currently has had the air ride removed and conventional struts installed. What other options exist? Are there other struts that will gain some clearance between the body and tires to allow me to put larger tires on? Quote Link to comment Share on other sites More sharing options...
northguy Posted July 27, 2005 Author Share Posted July 27, 2005 Bump - hoping for some input. Quote Link to comment Share on other sites More sharing options...
edrach Posted July 27, 2005 Share Posted July 27, 2005 Six feet of clearance; you must get some real snow in Chugiak! Sorry, it's the OCD in my nature! I would imagine that XSNRG or qman would have some thoughts on that. If I remember correctly, Ken's rallycross XT6 is higher than stock. I don't want to be plowing snow with the underside of it and would hope to have at least 6' of clearance, preferably more. Quote Link to comment Share on other sites More sharing options...
northguy Posted July 27, 2005 Author Share Posted July 27, 2005 Six feet of clearance; you must get some real snow in Chugiak! Sorry, it's the OCD in my nature! I would imagine that XSNRG or qman would have some thoughts on that. If I remember correctly, Ken's rallycross XT6 is higher than stock. Ken's is radically higher. I'm not looking for that much gain, just enough to make it up my drive in the winter when I get home and haven't had the chance to plow yet. (sorry about the oversight on the typo). Quote Link to comment Share on other sites More sharing options...
edrach Posted July 27, 2005 Share Posted July 27, 2005 No need to apologize...I was just pulling your chain. A modified version of what Ken has should work for you if that's possible. Ken's is radically higher. I'm not looking for that much gain, just enough to make it up my drive in the winter when I get home and haven't had the chance to plow yet. (sorry about the oversight on the typo). Quote Link to comment Share on other sites More sharing options...
tappermanor Posted July 27, 2005 Share Posted July 27, 2005 You could put a lift kit in it! scroll to bottom http://ozified.com/BYB%20lifted%20Subes%202.htm http://www.ozified.com/liftkits.htm The contact is a member of the board! I would like to do this to one of mine! in my spare time :-\ Tapper Quote Link to comment Share on other sites More sharing options...
NorthWet Posted July 27, 2005 Share Posted July 27, 2005 Like Ed said, contact Qman or XSNRG. How about air suspension in the "high" setting? Quote Link to comment Share on other sites More sharing options...
tappermanor Posted July 27, 2005 Share Posted July 27, 2005 But he has conventional springs. If someone has air ride and wanted to add a "candian model" type low/high switch, check this thread: http://xt6.net/forum/viewtopic.php?t=3885 I personally have not tried it yet. Tap Quote Link to comment Share on other sites More sharing options...
NorthWet Posted July 27, 2005 Share Posted July 27, 2005 But he has conventional springs. If someone has air ride and wanted to add a "candian model" type low/high switch, check this thread: http://xt6.net/forum/viewtopic.php?t=3885 I personally have not tried it yet. Tap Hmmm... the US wagons already have a low/high switch on the same panel as the defroster. Quote Link to comment Share on other sites More sharing options...
tappermanor Posted July 27, 2005 Share Posted July 27, 2005 Yaa, too bad the XT / XT6 never had that option Quote Link to comment Share on other sites More sharing options...
tappermanor Posted July 27, 2005 Share Posted July 27, 2005 On the "candian model" the switch is where there is a blank this the pic. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 2, 2005 Share Posted October 2, 2005 i would so like to give my XT6 a few extra inches as well. the air ride definitely rides higher than every conversion i've done, but you should already have that if it's an AWD XT6 and you didn't convert it to coil overs. Yaa, too bad the XT / XT6 never had that option dang, how did i miss this thread, must have been traveling or something. tapper - the XT did have that option, some XT Turbo's anyway. the US XT6 never did. i just installed a canadian height switch in my XT6. after testing it (didn't work) and looking into it, it will require a tiny bit of electrical fiddling to make it work. i forget exactly what i need to do, but it's not that radical, need to run an extra wire or something. i can post more later if anyone is interested. you don't even need that button at all, if you just want to install a momentary switch yourself. it's a momentary type switch, not a toggle switch. i posted to shady's thread in the for sale section, who was offering the Allied Armament lift kit for EA82's (and others) and he seems to think it would work on the XT6. at some point i'd like to look into making my own lift kit of a couple inches, retaining the stock air suspension. don't know when i'll have time, won't be anytime soon. Quote Link to comment Share on other sites More sharing options...
operose Posted October 2, 2005 Share Posted October 2, 2005 I'm thinking maybe qman's setup for winter (we get deep snow here) and the struts/springs that are on it now for summer Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 2, 2005 Share Posted October 2, 2005 what is qman's setup? Quote Link to comment Share on other sites More sharing options...
operose Posted October 2, 2005 Share Posted October 2, 2005 what is qman's setup? '92 legacy GR-2's with legacy wagon springs on front XT6 GR-2's with stock xt springs on rear that's what his thread on xt6.net says... not sure if the "stock xt springs on rear" is the stock xt6 springs, or actual XT springs Quote Link to comment Share on other sites More sharing options...
Qman Posted October 2, 2005 Share Posted October 2, 2005 The front suspension and brakes are from a Legacy. The struts/shocks are indeed KYB GR-2's. The front springs are Legacy as well. I can't be certain if the rear springs are XT/6 or wagon. I tried the Honda front spring mod and couldn't compress them so I took them off. Not to mention that it was another 4 or 5" taller than now. Quote Link to comment Share on other sites More sharing options...
ezapar Posted October 2, 2005 Share Posted October 2, 2005 Ken's is radically higher. I'm not looking for that much gain. Why not? It would be great for winter. Just get another set of struts that will fit bigger tires, (some of those Coopers?) and run them for winter. Swap them out come spring. A couple hours tops would be worth it for your AK winters. Ken's XT6 handles better than you might think. Quote Link to comment Share on other sites More sharing options...
operose Posted October 2, 2005 Share Posted October 2, 2005 Why not? It would be great for winter. Just get another set of struts that will fit bigger tires, (some of those Coopers?) and run them for winter. Swap them out come spring. A couple hours tops would be worth it for your AK winters. Ken's XT6 handles better than you might think. that's what I'm saying too Quote Link to comment Share on other sites More sharing options...
XSNRG Posted October 3, 2005 Share Posted October 3, 2005 Yo...Just a stock set of GL wagon struts and springs in the back that will raise it about 3" (spring rate on the XT-6 and GL wagon are the same in the rear). I had to do a lot of mods on the rear struts to get it at that ride height. Not sure about the front but it sounds like a setup like Qmans would work. Quote Link to comment Share on other sites More sharing options...
northguy Posted October 3, 2005 Author Share Posted October 3, 2005 Don't get me wrong, Mark. I like the way it rides right now. I'm just looking for some snow clearance for winter. Quote Link to comment Share on other sites More sharing options...
XSNRG Posted October 4, 2005 Share Posted October 4, 2005 No need for explanation, I totally understand what you want/need to do. I have a set of stock 2wd XT-6 rear units that will raise you up about 3 inches, let me know if you want them. Stock wagon setup will accomplsh about the same thing, may jack it up more though. I'll try to get a comparison on length, I know the springs are the same rate. Don't get me wrong, Mark. I like the way it rides right now. I'm just looking for some snow clearance for winter. Quote Link to comment Share on other sites More sharing options...
bulwnkl Posted October 4, 2005 Share Posted October 4, 2005 When you talk about wagon struts & springs raising the car, are you talking about 2WD or 4WD? I ask because I put 4WD wagon parts under the rear of mine so that I didn't raise it up like 2WD XT struts would. Just curious. Quote Link to comment Share on other sites More sharing options...
