Subyaddict Posted July 26, 2005 Share Posted July 26, 2005 Power steering. Seems to have a little play on the pass. side cylinder Should I put new seals in it, or just get a new tie rod? Link to comment Share on other sites More sharing options...
Ross Posted July 26, 2005 Share Posted July 26, 2005 depends, if the play is up and down at the end of the rack, re bush or replace the rack. If its play in the ball joint at the end of the rack, replace the tie rod. If its play in and out of the rack, replace the rack. Link to comment Share on other sites More sharing options...
