If a crankshaft bolt works loose and ruins the crankshaft, is the pulley and related parts still okay? Asking because I will be using some used parts on my engine job. I'm thinking they'd be fine, but wanted to check. Thanks.
The harmonic balancer and key are usually ruined before the crank's keyway is damaged.
Thanks guys. One other question: does the harmonic balancer part ever wear out? I know that on some GM cars, there is a rubber part in the harmonic balancer that starts to degrade/crack and wear out. I don't know if this is true for subaru.
I don't know enough first-hand to tell how much risk there is. I remember looking at someone's Vanagon conversion site (can't find anymore) showing a salvaged EJ22 they bought with a broken pulley, and timing cover too as a result. As long as you have it off and verify it's a two-piece, might be a good idea to replace it.
