safe temp ranges?/ cooling issue
so around town in the rx i run about 182-190 degrees
when i get on the highway it gets up to about 200-220 degrees f...
or so the laptop shows me and the dash gauge shows its higher than it should be
not into the red yet but about 1/4 inch away from it if not less
and i can't seem to figure out why
thats with a 180 tstat the e fan hardwired to a relay and the mechanical fan also
and once i get off the highway 65-70 mph driving
it seems to take a loooong time for the cooling system to recover back to where it normally sits at during around town driving
so whats the safe zone as far at temp goes before i really have a problem
and anyone got any idea's?
well i went out and played with the injection settings..
i think i was dumping to much fuel in on top of the potential radiator problem
turned down the injector settings a tad and went and beat on it on the freeway for a bit
and it stayed downa round 197-200 so thats at least a improvement pulls a bit harder to yay.. still want it to run cooler
So... does the radiator have cold spots? I would imagine with a proper 192degree thremostat, the car should run at 190-200degF. With the cooling system working you should not see more than a few (2-5?) degree rise from "normal" (about what the t-stat is rated at). Any noticeable rise above the t-stat temp indicates a cooling system problem.
