danz75 Posted July 28, 2005 Share Posted July 28, 2005 Does anyone know what size is the AT drain plug on 2003 OBW 4cyl? Any special tools needed? Do you need to drop the pan in order to change the AT filter? Thanks. Link to comment Share on other sites More sharing options...
Tiny Clark Posted July 28, 2005 Share Posted July 28, 2005 That's why there is a drain plug, so you don't have to EFF with the pan. Link to comment Share on other sites More sharing options...
jayhawkroy Posted July 28, 2005 Share Posted July 28, 2005 Our legacies take 17mm socket for drain plug, for both 2.2 (1999)or 2.5 (2003) engine. Trans filter is external and spin on. I suspect your is the same. Link to comment Share on other sites More sharing options...
danz75 Posted July 29, 2005 Author Share Posted July 29, 2005 Our legacies take 17mm socket for drain plug, for both 2.2 (1999)or 2.5 (2003) engine. Trans filter is external and spin on. I suspect your is the same. Thanks for the reply. Since I have mostly sockets and have been told that some AT drain plugs are not the conventional type but stars or hex heads, I was concerned about having the right tool for the job, plus I do not seem to have very good luck with hex or star heads and usually end up stripping them. I'm glad to know that the AT filter is external and does not require me to drop the pan. I have dropped a few pans before and it is always not a pleasant job. Thank you. Link to comment Share on other sites More sharing options...
