DR 5 speed gear ratios?
What are the gear ratios in my 1986 GL Dual Range 5 speed manual transmission?
I am trying to figure out how fast I am really traveling MPH with the 26" tires.
I can use this formula if the 5th gear was a 1:1 ratio.
RPM = (MPH X Gear Ratio X 336) / Tire Diameter
OR
MPH = (RPM X Tire Diameter) / (Gear Ratio X 336)
OR
you can plug in your tire sizes here for a multiplier....
http://www.miata.net/garage/tirecalcold.html
