$ubaroo Posted July 29, 2005 Share Posted July 29, 2005 I keep going threw brake fluid, but can't find where it is going? normaly if it is a wheel cylinder you will see brake fluid all over the inside of the wheel that has the leaking wheel cylinder.. I have none I searched high and low I can not find brake fluid leaking anywhere.. Followed all the break lines don't see no leaks there either.. no visible leaks at the master cylinder or the hill holder thingy either.. Anyone have this happen to them?? it is a 1990 loyal wagon Link to comment Share on other sites More sharing options...
s'ko Posted July 29, 2005 Share Posted July 29, 2005 look at where drips. That may be a good sign as to where it is leaking. Most likely it's the hillholder. Good luck BW Link to comment Share on other sites More sharing options...
$ubaroo Posted July 29, 2005 Author Share Posted July 29, 2005 thats just it i can't find a leak any where, no puddles of brake fluid any where no drips either.. just gone.. Link to comment Share on other sites More sharing options...
Sweet82 Posted July 29, 2005 Share Posted July 29, 2005 Did you see this thread??? http://www.ultimatesubaru.org/forum/showthread.php?t=39459 Your not the only one... Good Luck, Glenn 82 SubaruHummer 01 Forester Link to comment Share on other sites More sharing options...
$ubaroo Posted July 30, 2005 Author Share Posted July 30, 2005 no i didn't but it was very helpfull, got some new stuff to try.. thnxs.. Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted July 30, 2005 Share Posted July 30, 2005 look under the master cylinder, where it bolts to the vacuum booster. is there any rust on the booster? or is there any fluid running down there? ive seen a few leaks at the rear of the master cylinder, and the vacuum booster was sucking up the fluid.... just a thought Link to comment Share on other sites More sharing options...
$ubaroo Posted July 31, 2005 Author Share Posted July 31, 2005 there is rust there too!! you might have something there.. So would i just remove MC clean it up with a new gasket or seal or change vac pod all together?? never done this before.. but i do have a aprts car so changing vac pod would be no problem.. Link to comment Share on other sites More sharing options...
