the_postie Posted July 30, 2005 Share Posted July 30, 2005 i'm about to put a mpfi ea82t into my mpfi ea82 n/a touring wag[hotwire afm photo dist].from what i've read you can use all the n/a stuff[ecu afm dist]on the turbo motor and drop in.is it needed to change the ecu signal from n/a to turbo,if so which pin is the turbo on the ecu and do you need to unplug the n/a signal?are these both ground?can a knock sensor be run with the n/a ecu,is it needed? Thanks Will Link to comment Share on other sites More sharing options...
