moshem74 Posted August 1, 2005 Share Posted August 1, 2005 hi today i change my fuel filter and also i changed all the fuel lines under the car, all off them are new with new houses. now, i saw that i have something that is broken there, i put a pic from haynes loyale book, number 25 the haynes book saied its tow way valve...o.k. so....whay do i need it , should i buy a new one if it broken?, what is it? do i need it? i saw that this part is broken and also it have a line that come to it and secound line that going from this part is not connecting to nothing = to the open air, does it need to be this way? also my car is loyale carborator with no canister under the hood, maby this part is for canister only? can i take it out? what should i do with the line that come to it, should i close it? thank you for your fast answer. no one know what it is so....maby one here from the profeshional subaru will. thank you. moshe. Link to comment Share on other sites More sharing options...
moshem74 Posted August 1, 2005 Author Share Posted August 1, 2005 here its bigger... Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted August 1, 2005 Share Posted August 1, 2005 moshem, the 2 way valve relieves excess pressure from the gas tank by venting gas vapors to the charcoal cannister, or allows fresh air into the tank when it gets cold. If you're sure you don't have the cannister then the valve is doing nothing. I suspect you could plug those line without a problem, but make sure you have a vented gas cap. Link to comment Share on other sites More sharing options...
moshem74 Posted August 1, 2005 Author Share Posted August 1, 2005 hi i have a vented gas cap. are you shour? so...can i take this two way valve a way? what to do with the line that goes in to it? should i close the line that goes in to it or what? thank you . Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted August 1, 2005 Share Posted August 1, 2005 I'm pretty sure. Why did you replace the lines? Did it run before? Does it run now? If it runs, I'd leave it be. That valve is part of the emission control system, and designed to let the canister store gas fumes until they're sucked into the carb. Otherwise the fumes are vented to the atmosphere, not good for the enviroment. But... if you don't have the canister, then the valve is useless. You said it's broke, so it's probably not functioning anyway. As for the gas lines, you could connect them together or plug them off as long as your gas cap is vented. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted August 2, 2005 Share Posted August 2, 2005 if by broken you mean it just had a hose hooked to it, but not connected to anything else that is how it came from the factory in L-series cars without evaporative emissions...ie there's nothing wrong with your cars fuel plumbing Link to comment Share on other sites More sharing options...
moshem74 Posted August 2, 2005 Author Share Posted August 2, 2005 this valve have 2 connction points, one up and one down, the upper is connecting to the fuel lines, the down is not conecting to no where. whan i mean broken, i mean = the down part of this 2 way valve its like missing par, just the down part of it, also i took it out and no fuel is there..... what do you say? Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted August 2, 2005 Share Posted August 2, 2005 My car is like you describe yours; '..this valve have 2 connction points, one up and one down, the upper is connecting to the fuel lines, the down is not conecting to no where..' So is EVERY carburetted L-series imported to Barbados (my home) by our local dealer, what you describe is NORMAL.. this is how the car came from the factory if it didn't have evaporative emissions (charcoal canister).. Do not be concerned by this in the slightest.. Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted August 3, 2005 Share Posted August 3, 2005 Thanks, PoorManImprezza! moshem, although they are fuel lines, they don't carry fuel, only fuel vapor. Link to comment Share on other sites More sharing options...
