rem14 Posted August 2, 2005 Share Posted August 2, 2005 Hi All, I just wondered if you use anti-seize compound on sparkplugs when put into an aluminum head? What torque values do you then use? THANKS! Link to comment Share on other sites More sharing options...
frag Posted August 2, 2005 Share Posted August 2, 2005 I use anti-seize. The torque value is 15 ft-lbs. Link to comment Share on other sites More sharing options...
swc7916 Posted August 2, 2005 Share Posted August 2, 2005 I ALWAYS use anti-seize on sparkplugs. Link to comment Share on other sites More sharing options...
Scottbaru Posted August 2, 2005 Share Posted August 2, 2005 Copper anti-sieze. Link to comment Share on other sites More sharing options...
rem14 Posted August 3, 2005 Author Share Posted August 3, 2005 Thanks for all the reply's! Link to comment Share on other sites More sharing options...
Setright Posted August 4, 2005 Share Posted August 4, 2005 Yes, just to add to the consensus: Copper anti sieze and roughly 15ftlbs. I have stopped using my torque qrench on plugs cause off access problems on my IMpreza - old Legacy was better. I tighten with an eight inch handle and stop when i feel "resistance". Don't force them. Of course if they are too loose they cannot dissappate the heat. Link to comment Share on other sites More sharing options...
Tiny Clark Posted August 4, 2005 Share Posted August 4, 2005 No. Link to comment Share on other sites More sharing options...
cookie Posted August 4, 2005 Share Posted August 4, 2005 and the application. Some plugs antisieze is not reccomended with. I like to buy reccomended plugs from the dealer these days and use what the factory (not Haynes) manual says to install them with. I know this is not very adventurous, but it usually works. Link to comment Share on other sites More sharing options...
Tiny Clark Posted August 5, 2005 Share Posted August 5, 2005 Using copper on aluminum is an aerospace vehicle no-no. Link to comment Share on other sites More sharing options...
nipper Posted August 5, 2005 Share Posted August 5, 2005 I use oil from the dipstick on the threads. I dont use a torque wrench on it myself, as i have a claibarted arm but yes 15 ft-lbs. nipper Link to comment Share on other sites More sharing options...
Lawsonmh15 Posted August 6, 2005 Share Posted August 6, 2005 nipper said: i have a claibarted arm but yes 15 ft-lbs. nipper I have a calibrated arm too. But it's calibrated for mid-stroke speed. Link to comment Share on other sites More sharing options...
Scottbaru Posted August 7, 2005 Share Posted August 7, 2005 Tiny Clark said: Using copper on aluminum is an aerospace vehicle no-no.Aren't the plugs steel in aluminum? Zinc anti-sieze would be better for corrosion, but it turns hard and crumbly in the heat. Maybe moly grease? I don't expect to get any corrosion in this dry application, I'll stick with copper. Link to comment Share on other sites More sharing options...
frag Posted August 8, 2005 Share Posted August 8, 2005 Scottbaru said: Aren't the plugs steel in aluminum? Zinc anti-sieze would be better for corrosion, but it turns hard and crumbly in the heat. Maybe moly grease? I don't expect to get any corrosion in this dry application, I'll stick with copper. The one I use only states thet it contains «petroleum distillates and aluminum» Its marketed by Permatex in a small gray plastic container and claims to protect any metal from corrosion and seizing at temps up to 1600 °F. I would trust that cuts the mustard. Link to comment Share on other sites More sharing options...
Pascal Giasson Posted November 26, 2006 Share Posted November 26, 2006 If you use antiseize compound on your plugs, the Subary factory manual says to reduce torque by 1/3. BTW, this applies to any nut or bolt torque setting with antiseize or lubricant, not just the plugs. Link to comment Share on other sites More sharing options...
Petersubaru Posted November 27, 2006 Share Posted November 27, 2006 and of course, to much anti-sieze could prevent the plug from properly grounding the current Link to comment Share on other sites More sharing options...
beataru Posted November 27, 2006 Share Posted November 27, 2006 Heres what I have heard, about anti seize,... Ive heard that it kills 02 sensors like no other... I have also heard many old timer mechanics swear by it... now I do trust old mechanics words but remenber... 350 chevys dont have 02 sensors..... Just my thoughts... I dont use it unless the factory manual says so... things "shouldnt"(baring the car has been in an airconditiond lab all of its sheltered life) Seize if the correct torque and not a smidge more is applied... Link to comment Share on other sites More sharing options...
Setright Posted November 27, 2006 Share Posted November 27, 2006 How much grease are you guys applying? I smear a blot about 8mm in diameter on one side of the threads, avoiding the two top threads to keep the grease out of the chamber. Link to comment Share on other sites More sharing options...
