mcbrat Posted August 2, 2005 Share Posted August 2, 2005 and they will work on other applications (jeeps, soobs, etc...) http://www.dual-concepts.com/components/ Link to comment Share on other sites More sharing options...
Sweet82 Posted August 2, 2005 Share Posted August 2, 2005 I'll add a pic.... 56K warning!!! http://www.rhinobuggies.com.au/images/stalkerdualy.jpg http://www.rhinobuggies.com.au/images/stalkerdualy1.jpg For those of you who don't wanna pull it up, It's RhinoBuggy with Dual Wheels. I believe they are probably 15". The Buggy is a RhinoBuggy Stalker. 100% Subie at heart. While I'm at it... I'm not sure Duallies are really a solution to anything. I'd think they would cause more problems than they'd solve. My .02 Glenn 82 SubaruHummer 01 Forester Link to comment Share on other sites More sharing options...
Andyjo Posted August 2, 2005 Share Posted August 2, 2005 They're for carrying more weight.. right? well a subaru suspension will destroy itself by the time the 2nd wheel would ever help you.... It sure would look funny though. Link to comment Share on other sites More sharing options...
subarubrat Posted August 3, 2005 Share Posted August 3, 2005 I was thinking it would be great to put the Bushwhacker rear flares on with the Dually kit after doing a 15in 6 lug conversion. Then stuff in an Isuzu 6cyl diesil, on a BRAT of course. Link to comment Share on other sites More sharing options...
Andyjo Posted August 3, 2005 Share Posted August 3, 2005 i want to see a new gen with those on it.... and then i'd cry laughing so hard Link to comment Share on other sites More sharing options...
Numbchux Posted August 3, 2005 Share Posted August 3, 2005 on full-size trucks...yes, more weight...on an ORV...more surface area...idea being, floating over the mud, instead of sinking into it. Skinny tires are great for getting through the crap down to the solid base, but if the whole is deep enough, you'll get high-centered before you reach bottom. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 3, 2005 Share Posted August 3, 2005 Chux is right. Normally a dually is made to support more wieght (distribute the wieght more evenly). But in a situation like this you'd want duallies so you can stay on top of the snow/mud instead of sinking into it. -Brian Link to comment Share on other sites More sharing options...
soobmater Posted August 3, 2005 Share Posted August 3, 2005 duallies would make a soob be able to go threw like 8 feet of snow, cause it would just stay on top:lol: Link to comment Share on other sites More sharing options...
Andyjo Posted August 3, 2005 Share Posted August 3, 2005 well the average subi is what... 2500lbs.. ish so on 4 wheels you get 625lbs each... with 8 you'd get 312.5lbs each... that is if it's evenly distributed.. which it isn't... but still! not to shabby! i want a set fo rall 4 corners Link to comment Share on other sites More sharing options...
MorganM Posted August 3, 2005 Share Posted August 3, 2005 http://www.dual-concepts.com/gallery/ Notice the very light ATV is sunk into the mud in several pictures...not floating on top if it. Dualies are for agricultrual implement or towing; not offroading. Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted August 3, 2005 Share Posted August 3, 2005 Woul'nt this type of dually be hard on the bearings?,,,, considering that Highway duallys are usally balanced and mounted where the two halves meet. however with this set-up the mounting point stays the same and more leverage is given to the outside wheel to pry against the bearing. Am I right or do i have the wrong understanding? Link to comment Share on other sites More sharing options...
subynut Posted August 4, 2005 Share Posted August 4, 2005 Yes, it would eat the bearings in a hurry. Cool idea, tho. I remember seeing sombody put duals on a ea81 wagon just so they could run though a mud bog at one of those truck mud bog events. From what the article said, he did very well. Didn't get all the way through, but he got a long waze in! Now, if I could only remember which magazine it was I read that in........hummmmm...it was either 4wheeler or peterson's 4wheel&off-road. Link to comment Share on other sites More sharing options...
Numbchux Posted August 4, 2005 Share Posted August 4, 2005 MorganM said: http://www.dual-concepts.com/gallery/ Notice the very light ATV is sunk into the mud in several pictures...not floating on top if it. Dualies are for agricultrual implement or towing; not offroading. well, maybe 'floating' isn't the right term, but it won't sink as far as without them. I know it would've gotten my buddies ATV much farther a few times out in the swamp yep, this would be horrible for the car, the leverage would be very hard on wheel bearings, and probably tie rod ends, and ball joints too. Link to comment Share on other sites More sharing options...
LoyaleFan Posted August 6, 2005 Share Posted August 6, 2005 MorganM said: http://www.dual-concepts.com/gallery/ Notice the very light ATV is sunk into the mud in several pictures...not floating on top if it. Dualies are for agricultrual implement or towing; not offroading. It looks as though if you had front duals then you'd be doing more "plowing" through mud than just floating over it. I think that you would lose a lot of momentum trying to get through that messy stuff. For mud, I'd skip the duals in the front. Link to comment Share on other sites More sharing options...
Hondasucks Posted August 6, 2005 Share Posted August 6, 2005 I think I need to make a quad-cab dually Brat when I get my shop going.. That would be S I C K! lol Put one of the little Cummins like 25 HP three cylinder diesel engines in it :-P Link to comment Share on other sites More sharing options...
Tbird Man Posted August 6, 2005 Share Posted August 6, 2005 Three reasons to add dullies. 1. It's cool. 2. 4>2 3. it's cool. Link to comment Share on other sites More sharing options...
subynut Posted August 6, 2005 Share Posted August 6, 2005 Hondasucks said: I think I need to make a quad-cab dually Brat when I get my shop going.. That would be S I C K! lol Put one of the little Cummins like 25 HP three cylinder diesel engines in it :-P Mmmmmm.....torque! Link to comment Share on other sites More sharing options...
Zefy Posted August 7, 2005 Share Posted August 7, 2005 i have a set on my brat... just got them yesterday... really easy install... look pretty mean too... NAH... i'm messing with you... i wouldn't buy those... maybe some people in greenland would enjoy those... they need super wide tires don't they??? Link to comment Share on other sites More sharing options...
idosubaru Posted August 7, 2005 Share Posted August 7, 2005 that one picture i looked at had duallies but i've seen plenty of truck tires that are as wide as the two of those skinny things. and why the hell is everyone suggesting only stopping at two wheels on each axle? how about 3 or an extra set of axles...let get serious now and quit BSing. Tracks, now you're talking. Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted August 7, 2005 Share Posted August 7, 2005 Hondasucks said: Put one of the little Cummins like 25 HP three cylinder diesel engines in it :-P HUMMM,,,, How about an subaru Horizontaly Opposed Diesel,,,, that would be cool! call it the Subaru H.O.D. just imagin the gass milage! Link to comment Share on other sites More sharing options...
Numbchux Posted August 7, 2005 Share Posted August 7, 2005 grossgary said: Tracks, now you're talking. yea...what are they called Mattraxx or something? I see 'em at the State Fair every year and think "I wonder if that would fit on my sub", than see the price (5 digits, easy) and it never becomes of anything. Link to comment Share on other sites More sharing options...
Hondasucks Posted August 9, 2005 Share Posted August 9, 2005 FirstSubaruGLwagon said: HUMMM,,,, How about an subaru Horizontaly Opposed Diesel,,,, that would be cool! call it the Subaru H.O.D. just imagin the gass milage! If I could FIND one of those, I'd have one in my car! Veggie Roo Link to comment Share on other sites More sharing options...
airbag_89 Posted September 1, 2005 Share Posted September 1, 2005 LoyaleFan said: It looks as though if you had front duals then you'd be doing more "plowing" through mud than just floating over it. I think that you would lose a lot of momentum trying to get through that messy stuff. For mud, I'd skip the duals in the front. if you had duallys on front you would glide over top if you had none on front you would do a nose dive youd think. Link to comment Share on other sites More sharing options...
MorganM Posted September 1, 2005 Share Posted September 1, 2005 airbag_89 said: if you had duallys on front you would glide over top if you had none on front you would do a nose dive youd think. You'd think so but it doesnt really work that way. Link to comment Share on other sites More sharing options...
