lift kit
old sub freak
aargh delete it quick! Hehe, I got flamed harshly a year ago when I posted this question!!! In case you didn't know, the kits are made in small quantities, by a local of the board, not some larger manufacturer one wouldn't feel bad about ripping off. (Which is what I had thought, being a newb at the time)
I remember when you posted the question last year Basher.
We'll let todds down lightly. I think the only people who has blueprints of a solid and tested true lift kit are BYB and PK Davis. John (mudrat) knows how to lift sube's, and he could probably build a lift for you.
As far as blueprints, you'll probably need to make some yourself. Its not that difficult to lift a sube, its manufacturing the blocks.
-Brian
ya really it's not tough you don't have to deal with much geometry or anything. Mine's gonna be made out of the frame of an APEX stair climbing exercise machine! I know it sounds bad but its 3"x1.5" 3/16 wall rectangle, I'm pretty sure. It'll be doubled up for 6", with lots of bracing. Should look kinda like hassey's 6" brat lift. If you're confused about building a lift just look at each mounting point for the subframes, and design a block that will drop each down how ever many inches you want.
If you have never dealt with a lift before it would probably be simpler and safer to buy one. Once you figure out exactly how they work fabbing your own can work... but after you get all the parts plated and get all the bolts and stuff and spend all the time making stuff... its probably easier just to buy the kit from PK Davis
Another tough obsticale to your own custom lift is maintaining proper camber front and rear. Extending the steering shaft doenst look very easy either.
I agree with the statments above. Unless you really know what your doing with custom fabrication you are going to be spending a lot of time and money with just trial and error before even getting a lift you wiould be happy and safe with.
Heres a pic of a scorpion 50mm lift, basically you would make everything 2/3x taller. With this method you have to find or make bolts that are longer too. The other way like hassey's or subarubrat's brat is to make them out of rectangular tube, with some reinforcement, and and seperate bolts for the x-member and body.
scorpion:
subarubrat's lift:
Suabrubrat got the lift info from me and my site when i had my web site up
use 2x6 tubing and cut into 2x2x6 you will need 14 total for your brat that 10 in the front (5 on each side) and 4 in the rear (2 on each side)
drill holes in both ends of all 14 blocks use the orignial bolts and bolt all 10 blocks in place in the front flat sides faceing towards the front the 5th block on the inside will have the flat side facing the tire
use 2x2 tubing and measure and cut to fit in between the blocks and weld them in place conecting all 5 blocks together
do the same in the rear except you will also run a piece across conecting both sides
You will have to buy 14 nuts and bolt for the bottom of the lift
you will use 2x2 tubing and cut a piece and conect the front of the lift to the rear
so when all is done you have built a sub frame that is solid and will not rock back and forth
that just the basics theres a lot more involed in building the strut towers the rear shock mounts so you can run bigger shocks and even dual shocks if you wanted too
and re building the rear suspention out of 2x2 tubing
DO NOT USE 7" bolt like some people on the board thinks i did
I personaly would not trust the 4" or 5" bolts that come with the byb/pk lifts
Hassey
