Do It Sidewayz Posted August 5, 2005 Share Posted August 5, 2005 what lug nuts are people using with their Pug wheels?? i managed to find a couple sets of these things today. A set of steelies that do look like aftermarket wheels, and a set of alloys. It looks like Pug used larger wheel studs. probably 5/8" and almost looks like they use a 45 degree taper instead of the 60. what are people using? Link to comment Share on other sites More sharing options...
the sucker king Posted August 5, 2005 Share Posted August 5, 2005 it totally depends which pug wheels you've got. some work w/ subaru lugs, some don't. find your wheels on this page: http://www.ultimatesubaru.org/80s/wheels2/wheels.html and i'm sure somebody could tell you what you need. Link to comment Share on other sites More sharing options...
northguy Posted August 5, 2005 Share Posted August 5, 2005 I use standard lug nuts on the steelies, and Pug lug nuts on the alloys. Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted August 5, 2005 Share Posted August 5, 2005 If in doubt,,,, take one of your "nuts" to the auto parts store and buy 4 sets of shinny new mag nuts.. then you will have new "nuts" and the girls will love you... :-p Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted August 5, 2005 Author Share Posted August 5, 2005 well. these are the alloys and these are the steelies Link to comment Share on other sites More sharing options...
northguy Posted August 5, 2005 Share Posted August 5, 2005 Both sets are the same I am running. Regular lug nuts work fine on the steelies, but the mags require Pug nuts. If you find a suitable replacement, let us know. Link to comment Share on other sites More sharing options...
thealleyboy Posted August 5, 2005 Share Posted August 5, 2005 The problem with the alloy type nuts is that they are so uncommon. You will not be able walk into your local parts store and find these. I had a b*tch of a time finding a set for mine (thanks Chef Tim!!) Before finding my set, I had considered drilling out the holes and going with a universal mag-type lug nut (with washer). You could probably do this on your workbench if you have a brand new bit, and a steady hand. Having a machine shop drill them out would be even better. As far as the steels, you would have many choices - both OEM and aftermarket. good luck, John Link to comment Share on other sites More sharing options...
chef_tim Posted August 5, 2005 Share Posted August 5, 2005 http://www.ultimatesubaru.org/forum/showthread.php?t=31201&highlight=doorman That's what I've done on two of mine. Never had a problem. Tim Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted August 5, 2005 Author Share Posted August 5, 2005 So the stock Peugoet wheel nuts will work??? i may be able to get a set of these off the guy i'm getting the wheels from. failing which i might just get the steelies. or are you saying if i go to Longer wheel studs i will have no problem with the lugs?? and can use the factory subaru jobbies? Link to comment Share on other sites More sharing options...
northguy Posted August 6, 2005 Share Posted August 6, 2005 The alloys are such that the recesses are canted, they are sloped and the pug lug nuts have washers that are the same angle as the recess in the bolt hole. Hope that clears things up. Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted August 6, 2005 Author Share Posted August 6, 2005 weird....when i went to pick up these wheels. i asked buddy about the lug nuts. So he takes me over and shows me this entire drawer full of Pug lug nuts....so i take a look inside....IDENTICAL to the ones i'm using right now. says they have NO problem with them at all. Link to comment Share on other sites More sharing options...
northguy Posted August 6, 2005 Share Posted August 6, 2005 Ask what he wants for the drawer full. You could sell them in no time, if they are the ones with the washers attached. Link to comment Share on other sites More sharing options...
