JHH Posted August 6, 2005 Share Posted August 6, 2005 In Four Wheeler magazine they have a project Lexus that they used a custom cut piece of cutting board material. They explained that it was light, mildly flexable and worked better that metal since it let the rocks and other obsticles slide against it with little resistance. In the next months issue in one of the letters to the magazine they said that they were able to get a 4'x8'x1/2" sheet from a cabinet wholesale place for about $170. Has anyone heard of this or even tried it? Link to comment Share on other sites More sharing options...
subynut Posted August 6, 2005 Share Posted August 6, 2005 I donno. It's one thing for knives to push against it, but 3000+lbs of truck sitting on one point of a rock? I'll hafta see this in action. Link to comment Share on other sites More sharing options...
A DOG Posted August 6, 2005 Share Posted August 6, 2005 I donno. It's one thing for knives to push against it, but 3000+lbs of truck sitting on one point of a rock? I'll hafta see this in action. Word. I'll stick with a metal skidplate. Link to comment Share on other sites More sharing options...
samo Posted August 6, 2005 Share Posted August 6, 2005 I good cutting board is pretty strong, but I'd still prefer to have some metal under there to protect the vital stuff. Maybe put cutting board on the surface of the metal to help it slide easier? Link to comment Share on other sites More sharing options...
Shadyirishmen Posted August 6, 2005 Share Posted August 6, 2005 Go look under a 2000 (or somewhere in that era) GMC/Cheverolet S-10 or Jimmy ZR2 and you will see that instead of using metal they used some sort of composite material to make their skidplate. A friend of mine had one and he ran the Sh*t out of it and it was durable as it gets. I would take a piece of plastic any day over steel for a skid plate. Steel bends and gets all sorts of destroyed (depending how thick it is) it doesn't have memory like most composites that can go back to there original shape. Sign me up for some synthetic skidplates Link to comment Share on other sites More sharing options...
Matty B Posted August 8, 2005 Share Posted August 8, 2005 I donno. It's one thing for knives to push against it, but 3000+lbs of truck sitting on one point of a rock? I'll hafta see this in action. Years ago I was commercially diving and we ran sections of cutting boards instead of rollers on our boat trailer. We slammed 1500 Kilograms of boat and 1200-1400 Kilograms of sea urchins into these day after day after day. Still servicable when we sold the boat after 4 1/2 years. Thats gotta be 6000 lbs and with a sharpish edge hitting it too. I would say if they were well secured, these would work well. Use the thick ones though (3/4"). Link to comment Share on other sites More sharing options...
ballitch Posted August 8, 2005 Share Posted August 8, 2005 i would like to see the hard polyplastic cutting board material used in this application, light, easily replaced, but possibly not as resistent to heat as steel. although in the end steel is probably cheaper and fairly easy to weld, bend. ~Josh~ Link to comment Share on other sites More sharing options...
archemitis Posted August 9, 2005 Share Posted August 9, 2005 sounds expensive. i like metal, its cool... cant weld a cuttin board either. maybe it would be good for the ej offroadin croud, with the light offroad duty they pull... makes me want teflon sliders. Link to comment Share on other sites More sharing options...
Beegeer Posted August 9, 2005 Share Posted August 9, 2005 In Four Wheeler magazine they have a project Lexus that they used a custom cut piece of cutting board material. They explained that it was light, mildly flexable and worked better that metal since it let the rocks and other obsticles slide against it with little resistance. In the next months issue in one of the letters to the magazine they said that they were able to get a 4'x8'x1/2" sheet from a cabinet wholesale place for about $170. Has anyone heard of this or even tried it? HDPE, High Density Polyethylene. 4'x8'x1/2" sheet $117 www.mcmaster.com Link to comment Share on other sites More sharing options...
Sweet82 Posted August 9, 2005 Share Posted August 9, 2005 HDPE, High Density Polyethylene. 4'x8'x1/2" sheet $117 www.mcmaster.com The Competition Rock Crawlers are using this technology. I helped install it on this buggy. http://www.uroc.com/new/teampages.php?series=EXTREMEW Supermodified #10 (Whit)--the link won't take you all the way there. I think your going to see more and more of this type of armor in the future. Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted August 9, 2005 Share Posted August 9, 2005 actually. the cutting boards are made from UHMV (Ultra High Molecular Weight Polyethylene) Alot of rally cars use this under the floor boards of the cars to keep the pain from scraping right off and so on. some also use kevlar....which works even better. you will see ALOT more kevlar underbody protection used in the future Link to comment Share on other sites More sharing options...
