loyalewithcheese Posted August 6, 2005 Share Posted August 6, 2005 hey all, any tips on getting around a spark plug hole that is being a pia? i just keep trying and trying and it starts to feel good, then it stops. the threads look pretty good so unless i get overanxious i'm 95% sure all is fine, i just can't get it in the right way and it's driving me nuts! tia droo Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 6, 2005 Share Posted August 6, 2005 Just something to rule out: Is your sparkplug socket getting jammed up against the walls of the head casting? On my MPFI heads, this is a real issue, as one of my 2 sparkplug sockets has too thick of a wall to fit into the plug well properly (will go in, but "sticks" once torque is applied). Guess which one I always seem to grab first? Otherwise, I would try the socket and extension on the neighboring plug, memorize the "look" of the angles, and try your PITA plug again. Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted August 7, 2005 Share Posted August 7, 2005 you could buy a "thread chaser" and try to clean up the threads in the head... Quote Link to comment Share on other sites More sharing options...
N2FHL Posted August 7, 2005 Share Posted August 7, 2005 What's the difference between a thread chaser and a tap? Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted August 7, 2005 Share Posted August 7, 2005 tap is designed to cut new tight perfect threads chaser is designed to clean up and correct threads, much sloppier fit, and much easier to engage correctly. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 7, 2005 Share Posted August 7, 2005 I do not know that a threadchaser has any looser fit than a tap, but they are handy to have. They can also clean out the threads of the O2 sensor bung if you ever strip out a sensor while removing. Quote Link to comment Share on other sites More sharing options...
Marck Posted August 7, 2005 Share Posted August 7, 2005 Definantly use a thread chaser or tap to fix the thread. Also, put a lot of heavy axle grease oin the chaser or tap so that it will catch most of the shavings. Next time you install a spark plug, be sure to stick the plug into a 5/16 piece of hose and then use the hose to thread the spark plug in until it is hand tight. This will keep from stripping out those threads. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted August 7, 2005 Share Posted August 7, 2005 I usually use anti-seize on the spark plug threads for install - makes life at least a little easier - I would also try hand tightening the plug first (if it is on the passenger side that is easy to do) try that and a different socket before you think Helicoil - and even if you do have to helicoil, they aren't that hard to install if the plug is on the passenger side - I speak from expierence there (no I did not strip the plug hole out) BTW - use a name brand one IE HELICOIL - if not it is liable to shoot the spark plug out of the cylinder - I have expierence there too I actually have had the same problem with the socket hitting the casting, however I got rid of the one that had that problem. (it was a cheapie anyway) Quote Link to comment Share on other sites More sharing options...
loyalewithcheese Posted August 7, 2005 Author Share Posted August 7, 2005 thanks for the tips, i will look for a thread chaser. i was in a kragen today and asked for something like this before i read your responses and the parts goon shrugged in stupidity. believe me, i'm not suprised. i'll keep at it, i don't think there is any major damage so i think i can get it in there with some patience, and maybe some thread chaser help. this is on the left side/rear cylinder all others went on fine with the socket i have, it isn't too bulky and it does seem to be getting hung up. i'll poke around my motorcycles i think i have a tool kit plug socket that might be slimmer. cheers droo Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 7, 2005 Share Posted August 7, 2005 The sparkplug tap/chaser that I have is double-ended, with one thread size for standard-size plugs and the other end for smaller plugs (like in my Ferd Aerostar); socket hex midway along its length, black oxide finish. I think that I got it at NAPA. Quote Link to comment Share on other sites More sharing options...
