Psy890 Posted August 10, 2005 Share Posted August 10, 2005 Hi, I recently bought a 1996 Subaru Legacy with the 2.2L engine and automatic transmission. Under full throttle the transmission shifts at 6000 rpm. Is this typical of Subaru automatics or is it possible it has been modified? Link to comment Share on other sites More sharing options...
SuBrat84 Posted August 10, 2005 Share Posted August 10, 2005 Sounds about right... depending on how my legacy feels a lot of the time it will shift about 5500 rpms.. but sometimes I see it go up to about 6300 without me shifting it myself.. Link to comment Share on other sites More sharing options...
ballitch Posted August 10, 2005 Share Posted August 10, 2005 my 98' sedan shifts at about 5k at full throttle, unless i manually do it, my brothers' 95', however, shifts at redline too, mabye just different tunning from different ECU's, but his is FWD and my car is AWD, and i get better gas mileage, go figure. ~Josh~ Link to comment Share on other sites More sharing options...
jimscat Posted August 10, 2005 Share Posted August 10, 2005 my 93 will shift at redline (6500) only if I get the little green "power" light to come on. What does the "power" light mean? Link to comment Share on other sites More sharing options...
Tbird Man Posted August 10, 2005 Share Posted August 10, 2005 The power light is a power mode that comes on when you quickly depress the throttle. it changes the shift points to get more power at cost of fuel economy. So yes, this is why it shifts higher. Link to comment Share on other sites More sharing options...
nipper Posted August 10, 2005 Share Posted August 10, 2005 my 97 outback wil go right to red line if i let it when floored. It sounds like its operating fine. nipper Link to comment Share on other sites More sharing options...
Losiho Posted August 11, 2005 Share Posted August 11, 2005 My 99 Outback will change up at the redline (6,200) every time the throttle is floored. If you really get a good kickdown into 2nd, it will even change up at 6,400rpm (fuel cutout is 6,500). Link to comment Share on other sites More sharing options...
Legacy777 Posted August 11, 2005 Share Posted August 11, 2005 The programming in the 1st & 2nd gen legacys' TCU seems to automatically shift the transmission at redline. I know for a fact, the 1st gen legacies will shift at redline, even if the gear selector is in the "1" or "2" position. The newer cars don't do this, the rev-limiter kicks in. I don't know however when this actually took place. Link to comment Share on other sites More sharing options...
nipper Posted August 11, 2005 Share Posted August 11, 2005 The valve bodies will force a upshift out of self preservation (that goes for all automatics). Now with all the computers, they just limit the revs on the engine and not force the upshift. nipper Link to comment Share on other sites More sharing options...
Legacy777 Posted August 12, 2005 Share Posted August 12, 2005 I'm not so sure the valve body alone will force an upshift. These transmissions are electronically controlled, so the solenoids in the valve body will be actuated by the computer. Link to comment Share on other sites More sharing options...
nipper Posted August 12, 2005 Share Posted August 12, 2005 i guess its how its all programed. So far all the reveiws ive seen of the manual-matics will force an upshift a hair above redline. i know fuel injectors do stop operating at some point. But im sure somone out there is cutting off fuel...somone always has to be difficult nipper Link to comment Share on other sites More sharing options...
