Subi81 Posted August 10, 2005 Share Posted August 10, 2005 So I am trying to find out why my car has a rondom miss and TOD. Took off the valve covers and looked at the cam and HLA's. Is this what a flat cam MIGHT look like, I don't have a micrometer or caliper to measure it properly. So if this is what a flat cam looks like I will get one and measure it, to be absolutly sure. Also I noticed that I have some pitting right around the oil hole. Does anyone know what could have caused this? I am suspecting sloppy hydro lash adjusters because when I pushed on them they were deflecting pretty bad. Thanks Link to comment Share on other sites More sharing options...
NorthWet Posted August 10, 2005 Share Posted August 10, 2005 A "flat cam" refers to one or more cam lobes that have been worn down, usually identifiable by the huge score marks across the lobe face. The one lobe that I saw in your picture looked pretty good to me. Not much of an idea about the oil hole "pitting", unless somebody physically abused it earlier. I wouldn't expect to see pitting, as the wear mode should be scratching/scoring, and the oil hole is in a no-/low-load area. The HLAs easily depressing does not seem a good sign for them. Mine didn't really depress noticeably, but then mine were uptight when I tinkered with them. (They can drain some on their sides.) Link to comment Share on other sites More sharing options...
All_talk Posted August 10, 2005 Share Posted August 10, 2005 Yeah, I'm with Pat on this one, that wear pattern looks pretty normal. But you're right only a measure will tell for sure. Gary Link to comment Share on other sites More sharing options...
Subi81 Posted August 10, 2005 Author Share Posted August 10, 2005 Thanks Link to comment Share on other sites More sharing options...
