Maximum weight in Brat bed
What's the rated maximum haul weight for a Brat? Half ton? What's the most anyone has actually carried in one? I carried a "half load" of logs yesterday - probably about 1000 pounds. I would have carried more, but I was concerned that I was over the limit as it was. The tired ol' 1.8 agreed, as did the suspension. Good thing I didn't have to travel on the highway - I'm not sure I could have carried any significant speed up a hill.
Brad
I thought it said it was rated for #350? Which would be the weight of two people in the back. This would make sense if the suspension is the same as the other models.
Don't quote me on that!
Glenn,
82 Hatch, transforming:temper:
01 Forester, jealous :madder:
my cousin drove up from texas(to minnesota 900 miles) in a brat, and the rear end was sitting on the bump stops the whole way.. a full standup toolbox 400lbs? and everything else he owned. went 85 the whole way, with a 4 speed.
dont think you can overload them, once they are on the bumpstops, its all about how good your tires are
The rated cargo capacity of a Brat (Directly from owners manual):
"For the Brat, the maximum carrying capacity
consists of two passengers in cab, two
passengers in rear and 113 kg (250 lb) of
cargo or any combination of passengers
and cargo not to exceed 386 kg (850 lb).
Do not use the vehicle as a cargo carrier."
That should about take care of it. BTW - if you exceed these
limits, you will wear out wheel bearings and shocks, and
there is a possiblity of breaking the torsion bar in the rear.
