Melting Headlights ?
For a 1986 4WD turbo at , I would like to install 100/80 watt bulbs.
I know that it is only legal for off-road use....
Apart from extra relays and extra copper wires . do the plastic housing support
the (nearly) double power consuming ?
Who has some experience ?
Any input is welcome before may be burning my car !
umm ... there is no plastic housing in stock form - your headlights are glass and the bowles are steel with a chrome coating - so no problems there - the only plastic piece is the retainer for the bulb itself!
you will DEFINATELY need to run a completely seperate wiring harness/relays for the headlights, as your stock one will go up in smoke with that setup!!
umm ... there is no plastic housing in stock form - your headlights are glass and the bowles are steel with a chrome coating - so no problems there - the only plastic piece is the retainer for the bulb itself!...
This information is for USA models, per US Department Of Transportation regulations. I would be careful about assuming what other countries' regulations allow on Subarus.
The wiring is no problem (I am an electronic engineer) , but I doubt the plastic
part . It is the rear of the headlight (different in Europe ?) and carries not only the bulb but also gives the total stability of the headlamp.
So I would like to hear from people who really did this with pos/neg experience.
Thanks for all input !
