xoomer Posted August 12, 2005 Share Posted August 12, 2005 if you are interested in my saga at all. I have gotten my car to run.. its still got blowing head gasket but very light... so I am going to pull the motor... and do both sides... and new belts.. all that other stuff... Q: is motor removable with just you and friend to lift it out? Q: Best brand for replacement parts Q: What is the full over haul procedure I.E. New waterpump oil pump timing belts and new Gaskets? Anything else I should know before I start? -Xoomer ZOOM-ER for those who don't know how to say my name.... Link to comment Share on other sites More sharing options...
Indrid cold Posted August 12, 2005 Share Posted August 12, 2005 Q: is motor removable with just you and friend to lift it out? Yes, possibly, but better to have a third...I used two nylon slings and an 8 ft pole (pipe etc.) layed across hood, dropped slings on each side under heads and snugged up, put a guy on each end too lift up, one to pull motor forward and wiggle... Assure radiator was removed prior to pulling. Possibly a slight lift with floor jack under tranny to re-install. I am a "Noob with a wrench" so others can take it from here...... Link to comment Share on other sites More sharing options...
555Ron Posted August 12, 2005 Share Posted August 12, 2005 Q: Best brand for replacement partsOEM Subaru by far. If you do your research you can find the manufacturers of Subaru's parts and get them a little cheaper if money is tight. IMO, non genuine parts are not worth the money you pay for them for my experience. My waterpump is 1/8" too small for the timing covers. Subaru parts are the only thing to go onto my car from now on. Link to comment Share on other sites More sharing options...
calebz Posted August 12, 2005 Share Posted August 12, 2005 1- If you and your friend are both reasonably strong, the motor is easily removable by 2 people. 2- OEM subaru is the way to go 3- This realy depends on how far you want to go and how much you want to spend. I spent about $200 and got a complete gasket kit from a board member that worked at a dealership. It had every gasket I needed (and a few I didn't) Link to comment Share on other sites More sharing options...
