stephenw22 Posted August 13, 2005 Share Posted August 13, 2005 This seems quite possible, but will it cause me problems like pinging or such? The out-of province inspection on the hornet is almost done, but they need me to fix the oil leaks on the car. I have a nice spfi engine in my '88 with minimal leaking. It would be easiest for me to pull the engine out of the hornet and swap in the '88 engine. I'd have to change the manifold and disty, but that's easy. I'm just worried about the increased compression. I still want to use regular, not mid or premium. Gas prices here just went to CAD $1.06/litre - that's CAD $4.01/gallon, or USD $3.35/gallon. Link to comment Share on other sites More sharing options...
archemitis Posted August 13, 2005 Share Posted August 13, 2005 you could probably run the crappiest gas they sell, as long as the carb is jetted right. i doubt a stock subaru carb would feed it enough fuel. might have to use a weber so you can tune it... Link to comment Share on other sites More sharing options...
84gl Posted August 13, 2005 Share Posted August 13, 2005 the stock carb will work fine no mods needed but if you want more power a weber is what your looking for but it will burn a little more gas Link to comment Share on other sites More sharing options...
archemitis Posted August 13, 2005 Share Posted August 13, 2005 my spfi block didnt get enough fuel with the stock ea82 carb. it worked, but not superduper well. i bet it would pass emissions with flying colors tho Link to comment Share on other sites More sharing options...
stephenw22 Posted August 13, 2005 Author Share Posted August 13, 2005 I really don't care about power, all that matters is getting this car past the safety inspection. The oil leaks right onto the exhaust and smokes. There's a risk (however small it may be) of fire, so the leaks need to be stopped up before it will pass inspection. There's no emissions inspection to worry about for me, not in my province. Would my mileage go up? Just wondering... Link to comment Share on other sites More sharing options...
archemitis Posted August 13, 2005 Share Posted August 13, 2005 its probably nothing you would notice reely. but technicaly. the new motor wants more fuel than the old motor, because of its higher compression, so it could be runing lean unless you rejet. just listen for pinging, and set the timing right and you should be just fine. prolly better gas mileage, but you have to keep your foot out of her. Link to comment Share on other sites More sharing options...
NorthWet Posted August 14, 2005 Share Posted August 14, 2005 archemitis said: ... the new motor wants more fuel than the old motor, because of its higher compression, so it could be runing lean unless you rejet. ... There is no reason that the (marginally) higher CR would effect Air/Fuel ratio. It will not run any leaner/richer. It may be more prone to detonation, but the difference would be lost in the "noise" of all of the other variables that effect combustion. As archemitis said, retarding the timing by a degree or two would probably mitigate the detonation risk. Link to comment Share on other sites More sharing options...
