Differences between BYB 3/3" and 4/3" Lifts?
carfreak85
Did a search but came up empty. What is different between the two lift kits? The front strut mounts obviously, but are the engine and tranny crossmember spacers larger as well? Also, with a 4" front lift, is it necessary to trim the front fenders with 27 or 28 inch tires?
engine cross member blocks, and strut tops are 4"
radius rod blocks are 3" I think. maybe 3.5"
steering extension is a longer
you will still need to trim (or gently fold back :brow: ) the rear of the front wheel wells....
I have a 4/3 on my wagon. The radius rods are 3" long.
For a 27" tire, a little trimming on the front wheel well is necessary infront of and behind the wheel itself. If you follow the link in my sig, there is a picture of the minor trim-job. Rear tire will fit no prob.
