Try using the search function to pick up some more info, but here's some quick help.
It took me 5 days and a couple of posts here before I found where to connect the harness. The MY01 models have it all the way in the back compartment. Pick up the rear floor to expose the spare; on the right (passenger) side, there is a carpet panel on the floor with a syrofoam type spacer below it. Remove these, and then fish in the body frame openings along the outer body to find the plug. There are several harnesses you can buy, but they all need to have the electronics to switch the turn signal and brake lights to a single bulb per side setup. I was confused at first because ALL the instructions that come with the harnesses seem to list the plug on the driver's side for some reason. Maybe because it's written for a RH drive?
Edit:
this info is for an Outback, I would think the legacy wagons would be the same however after seeing some posts about the harness being listed for the Outback only, that may not be true. If you do have any luck finding the plug, let us know.
