soobscript Posted August 14, 2005 Share Posted August 14, 2005 I have an 88 RX with non-working AC due to compressor-pulley area. It is the rectangular compressor, outside of the alternator. I am pulling the engine, and having AC lines out of the way would make it much easier. You are supposed to take it to a professional for depressurization and stuff, but I want it out now. I've spent several hours on dial-up looking for info, and now I am asking. How do I do it the right way? The wrong way? --Ed Link to comment Share on other sites More sharing options...
NorthWet Posted August 14, 2005 Share Posted August 14, 2005 If all you are looking to do is to pull the engine without the A/C lines being an issue, just unbolt the A/C compressor mount-bracket from the engine and swing the compressor/lines/bracket over to the strut tower or battery-tray area. When the engine goes back in, just swing the A/C works back into place. Link to comment Share on other sites More sharing options...
soobscript Posted August 14, 2005 Author Share Posted August 14, 2005 NorthWet said: If all you are looking to do is to pull the engine without the A/C lines being an issue, just unbolt the A/C compressor mount-bracket from the engine and swing the compressor/lines/bracket over to the strut tower or battery-tray area. When the engine goes back in, just swing the A/C works back into place. I have done that already. But one of the line is still kind of in the way, annoying. I do not want non-functioning AC taking up space and weight in the car. Link to comment Share on other sites More sharing options...
LostWater Posted August 17, 2005 Share Posted August 17, 2005 There is a wrong way, and that means just unhooking the lines from the compressor, slowly. There is a good chance that it is empty anyways. Link to comment Share on other sites More sharing options...
MudisFun Posted August 17, 2005 Share Posted August 17, 2005 It is a bad idea to let anyone stand behind your shoulder while you vent r12! Releasing r134a is legal is most states I think, but venting freon should not be done, with anyone looking. If you talk to a shop that has the machine to evac r12 and it's pure, I'm sure they would be more than happy to. Link to comment Share on other sites More sharing options...
