xoomer Posted August 16, 2005 Share Posted August 16, 2005 The motor is out... stupid friends... didn't help... had to take the thing out all by myself... back hurts now... anyway does anyone know were one could get replacement bolts for all the ones I have lost during this escapade... the rebuild gets started on thursday.. hopefully will have completed by the end of september... tear down... wait for money... machine heads... wait for money... buy timing belts and head set... wait for money... buy replacements for anything I broke... rebuild... Get the title.. and register Wait for money.... Like I said... I am going to need a few replacement bolts for stuff that has just dissapeard... should I just go to a pap and yank said boltS? and then say there was nothing I needed? -Xoomer Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 16, 2005 Share Posted August 16, 2005 the "borrowing" of bolts fromt the PAP is a hotley debated issue, some things i don't mind taking, but i try to pay for most stuff, cause if they loose too much business then they go out of business. as for bolts, i don't think any of ours are torque to yeild so you should be ok, head and block bolts may be worth getting new though if your getting more boost or higher compression. Link to comment Share on other sites More sharing options...
MorganM Posted August 16, 2005 Share Posted August 16, 2005 Get them from the junkyard. I doubt they will even charge you; and if they do it will be for 'misc. items'. Local U Pull yard I go to won't even waste the time to ring up something that trivial. Link to comment Share on other sites More sharing options...
