  Legacy777 said:
If you're just purchasing a turbo.....then it would be rather difficult. You need exhaust piping, intake piping, bypass valve, oil lines to the turbo, and engine managment
What if I got that stuff too? Plus, you never said if it would fit or not. Will it?
As Matt mentioned, you can make anything fit.
You have two distinct paths in terms of fitment. Get a complete factory setup (that way you know it'll fit)
Or go with custom made stuff.
Either way, you still have to deal with electrical stuff, and Matt brought up a good point. Just putting a turbo on an engine that it wasn't meant for can cause some issues.
So a Stock WRX turbo would cause probs with my 2.5?
You'd have to replace parts of the engine. The best bet would be to look for a wrecked car that has a turbo engine in it, and do a swap.
The turbo makes a lot of heat and pressue...and a n/a engine might not take it very well.
