Subarutex Posted August 17, 2005 Share Posted August 17, 2005 87+ hot wire cars... do they have high or low impedance injectors? Quote Link to comment Share on other sites More sharing options...
Steveman09 Posted August 18, 2005 Share Posted August 18, 2005 high Quote Link to comment Share on other sites More sharing options...
john in KY Posted August 18, 2005 Share Posted August 18, 2005 I seem to recall low. 2.7 ohms. Easy enough to verify with a multimeter. Quote Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted August 18, 2005 Share Posted August 18, 2005 i can't remember which is which. but they are the opposite of "normal injectors" Quote Link to comment Share on other sites More sharing options...
Steveman09 Posted August 18, 2005 Share Posted August 18, 2005 2.7ohms isnt considering low impedance last time I checked. I used to have a pair of Performance Low Impedance Injectors for the Acura and they were like less than 1ohm Quote Link to comment Share on other sites More sharing options...
Subarutex Posted August 18, 2005 Author Share Posted August 18, 2005 Ok... are the injectors Peak and Hold? Or Saturated? Peak and Hold is supposed to be High Impedance Saturated is supposed to be Low Impedance Quote Link to comment Share on other sites More sharing options...
All_talk Posted August 18, 2005 Share Posted August 18, 2005 I thought they were LOW, thats why they need the resistors, to control the current. I thought low was around 3 ohms or less and high were around 12-16 ohms. I dont have my book here to check but the 2.7 number sounds right. Gary Quote Link to comment Share on other sites More sharing options...
Subi81 Posted August 18, 2005 Share Posted August 18, 2005 FSM says resistance should be between 2-3 ohms Quote Link to comment Share on other sites More sharing options...
oddcomp Posted August 18, 2005 Share Posted August 18, 2005 my my my .. sounds like someone is doing the covert megasquirt conversion... i could suggest you just run the injectors to the megasquirt and the cut the main lead to the resistor block and wire it to a relay that gets tripped from the + side of the coil wiring since its a switched + .... but then again what would i know.. Quote Link to comment Share on other sites More sharing options...
oddcomp Posted August 18, 2005 Share Posted August 18, 2005 ps low ohms = high amp loads .. high ohms = low amps loads stock suby injectors + stock resistor block = just fine in my setup Quote Link to comment Share on other sites More sharing options...
Subarutex Posted August 18, 2005 Author Share Posted August 18, 2005 Actually, i'm trying to determine if the DSM injectors I have fitted (which are high impedance) can be driven by the stock system without damage. I will not be upgrading to Megasquirt yet... but I have an SAFC to help tune for the larger injectors. Quote Link to comment Share on other sites More sharing options...
oddcomp Posted August 19, 2005 Share Posted August 19, 2005 measure the ohms across the terminals of the old injectors and the resistance of the dsm units then measure the resistance of the old resistors with the dropping resistor in line compare the 2 and see if you can run them with the resistor block or with out Quote Link to comment Share on other sites More sharing options...
Subarutex Posted August 19, 2005 Author Share Posted August 19, 2005 Ok... So I measured the resistance. 2.5-2.7 ohms on the stock ones... 11.4-11.8 on the DSM's. This was out of car. I guess I will be running the stockers to begin with. Please outline how to test with the "resistor block"... would this upp the OHM's of the factory injectors... thus meaning if I removed it and the stock injectors and ran with the DSM's it would be fine? Quote Link to comment Share on other sites More sharing options...
oddcomp Posted August 19, 2005 Share Posted August 19, 2005 disconnect the plug at the resistor block it should be the center pin thats the main power feed to the resistor block one probe of the ohm meter on the main power wire and the other from one of the resistor output wires actually now that i think about it look in a chiltons book or something like that it has the test measurments for the resistor block technically as far as i know if the combined resistance of your old injectors + the resistor block = to or pretty close to the dsm injectors.. then the dsm's should work minus the resistor block Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted August 20, 2005 Share Posted August 20, 2005 Ok... are the injectors Peak and Hold? Or Saturated? Peak and Hold is supposed to be High Impedance Saturated is supposed to be Low Impedance They are Peak and Hold 2.5s. Here is an old data sheet I posted up of my RX turbo injectors being cleaned at RC Engineering. On another unrelated note, you said you have (or will be using) an SAFC. I've asked a question many times to folks who have used the SAFC on older Subarus but never got a reply. My questions are: 1) What is your Sensor Number set at on your SAFC?, 2) What is your Sensor Calc set at on your SAFC? Please answer those if you can so I won't be frustrated for another year. Thanks! Quote Link to comment Share on other sites More sharing options...
