serotta50 Posted August 22, 2005 Share Posted August 22, 2005 I need to have my timing belt replaced on my 95 lsi wgn. Is there anything else I should have my mechanic do regarding seals, etc. when he has is off? Link to comment Share on other sites More sharing options...
mattocs Posted August 22, 2005 Share Posted August 22, 2005 also do the water pump, cam seals, oil pump seals. Its pretty much just parts costs since they already are doing work right there. Link to comment Share on other sites More sharing options...
serotta50 Posted August 23, 2005 Author Share Posted August 23, 2005 Thanks, seals it is, just told my mechanic today. Link to comment Share on other sites More sharing options...
svxpert Posted August 23, 2005 Share Posted August 23, 2005 how much is he charging to do the service? Link to comment Share on other sites More sharing options...
Adnan Posted August 23, 2005 Share Posted August 23, 2005 Hi, Not that it is directly related but you may want to check the condition of the valve cover gaskets, looking for leaks. That way, you can DIY later if need be. Regards, Adnan Link to comment Share on other sites More sharing options...
