Olnick Posted August 23, 2005 Share Posted August 23, 2005 Trunk lid is stuck shut on my daughter's '92 Legacy sedan. Neither the key nor the lever by the driver's seat will release it. Any suggestions? Is the rear seat back removable from inside the car? If it is, is there anything she could reach to release the latch from inside? Thanks in advance for any help or suggestions. Link to comment Share on other sites More sharing options...
paulbellefeuille Posted August 23, 2005 Share Posted August 23, 2005 Sounds to me like the cable is jammed at the latch end. Flip down the backseat, crawl into to trunk..carefully, and see if you can move the cable end at the latch. Trunk lid is stuck shut on my daughter's '92 Legacy sedan. Neither the key nor the lever by the driver's seat will release it. Any suggestions? Is the rear seat back removable from inside the car? If it is, is there anything she could reach to release the latch from inside? Thanks in advance for any help or suggestions. Link to comment Share on other sites More sharing options...
gbrand Posted August 23, 2005 Share Posted August 23, 2005 not all legacy seats flip down-but are not bad to remove. The rear seat cushion is held down by 2 bolts, and then once out of the way the seat back comes out fairly easilily If you dont have amnual go to autozone.com, click on repair infor and navigate to the diagrams that show how the seats come out. Link to comment Share on other sites More sharing options...
Olnick Posted August 23, 2005 Author Share Posted August 23, 2005 Thank you friends, am passing the info on. Search didn't reveal much about sedan latch mechanisms--anyone know if they're the same as wagon hatchs? Any hints/tricks appreciated. Aloha. Link to comment Share on other sites More sharing options...
