Idle and Timing Interdependency
My 84 carbed wagon's timing is advanced; therefore, my Idle is about 1K RMPs apposed to about 800 rmps. .......is this right? Should the idle be increased to compensate for the advance in the timing? Just wondering.
Thanks
So which way do you turn it to advance?
As you look down from above the disty, I believe it is clockwise to advance. Don't try it without a timing light- it will tell you which way you are going. Eight degrees before for the carbed engine.
