Signal Monkey Posted August 25, 2005 Share Posted August 25, 2005 I got a 2004 USDM WRX and I'm thinking about trying to get my hands on a EJ207 engine while I'm in asia.. I was hopeing that someone might have some/any information on an engine swap like this.. Any information would be very helpful. Thanks. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 25, 2005 Share Posted August 25, 2005 short answer, try www.nasioc.com they'll know more than we do long answer, you already have the turbo, it will be easier and cheaper to build power with the engine you have, unless the "JDM" is the most important factor. Try www.rallitek.com they'll give you more power than you know what to do with. OTOH, you should be able to get a JDM front cut here, talk with DR. RX he knows the hookups. Quote Link to comment Share on other sites More sharing options...
Signal Monkey Posted August 26, 2005 Author Share Posted August 26, 2005 short answer, try www.nasioc.com they'll know more than we do long answer, you already have the turbo, it will be easier and cheaper to build power with the engine you have, unless the "JDM" is the most important factor. Try www.rallitek.com they'll give you more power than you know what to do with. OTOH, you should be able to get a JDM front cut here, talk with DR. RX he knows the hookups. yeah I've been looking around nasioc.. it's not really about getting JDM.. well in a way it is.. I just hear a lot that the JDM EJ207 is much much stronger and can be tuned harder. Less problems with detonation. Plus it has the VVT.. Honestly I don't plan on doing too much tuning to my Subie, but I'd like to have a stong base to start with. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 26, 2005 Share Posted August 26, 2005 If you don't plan on doing much, don't do much to the US block. get an exhaust, maybe upgrade the turbo, clean up the intake, and then get a computer that is optimized to the whole system, fairly easy, but if it were me, i'd wait till the warranty is over, and then rage it. Quote Link to comment Share on other sites More sharing options...
