highpowerd2003 Posted August 25, 2005 Share Posted August 25, 2005 hELLO iM NEW TO THIS WEBSITE. i HAVE A 9O LEGACY WITH TEMP PROBLEMS. hAS NEW WATER PUMP AND RADIATOR. i NEED TO REPLACE THEMOSTAT. dO i NEED TO REMOVE THE TOP OF ENGINE, INTAKE, INJECTION TO REPLACE THIS PART. tHANKS dAN Link to comment Share on other sites More sharing options...
gbrand Posted August 25, 2005 Share Posted August 25, 2005 Thermostat housing where LOWER radiator hose attaches, kinda opposite old american cars. Prolly easier to get at from underneath not a bad job. Do a search on the board here and you will find lots of info. see pix http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1c/60/3a/0900823d801c603a.jsp Link to comment Share on other sites More sharing options...
MorganM Posted August 25, 2005 Share Posted August 25, 2005 Be sure to drain all the coolant out first. Or you'll get a face full of coolant when you pop that hose off! It's a simple repair. Just besure you dont put it in upside down! Note how the old one comes out as you are taking it out. Good luck! Link to comment Share on other sites More sharing options...
Legacy777 Posted August 26, 2005 Share Posted August 26, 2005 What sort of temp problems are you having? Was the cooling system properly bled? There is a bleed screw on the top of the passenger side of the radiator. Also, if you replace the thermostat, you need to replace it with an OEM subaru t-stat. aftermarket ones are shaped/sized different, and cause issues. Link to comment Share on other sites More sharing options...
