rubysubaru Posted August 26, 2005 Share Posted August 26, 2005 I do not have an impact wrench. I am trying to take off the right front axel nut. I just had a six foot black pipe on my tee bar and it still will not budge. I also heated the nut with a mapp gas torch. Am I wrong in presuming this is a regular right hand thread on the axel nut. If so I would like to kill the guy that over tightened the nut. I am scared the tee bar will snap. Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 26, 2005 Share Posted August 26, 2005 Make sure the wheel is on the ground, that makes it easier, or it did for me on one of my subies, on the other i'm also having a heck of a time. afraid i'm gonna throw my back out. Link to comment Share on other sites More sharing options...
wintersubaru Posted August 26, 2005 Share Posted August 26, 2005 lefty losey righty tighty Link to comment Share on other sites More sharing options...
rubysubaru Posted August 26, 2005 Author Share Posted August 26, 2005 I have the car tires on the ground and I am turning lefty loosy (counter clock wise). Also a note I did un-peen the castle nut part that was bent in to prevent it loosening out. I also just broke my Craftsman tee bar using the six foot pipe. I think I will go to a garage and give them twenty bucks to loosen it for me. Link to comment Share on other sites More sharing options...
thegnman Posted August 26, 2005 Share Posted August 26, 2005 I do not have an impact wrench. I am trying to take off the right front axel nut. I just had a six foot black pipe on my tee bar and it still will not budge. I also heated the nut with a mapp gas torch. Am I wrong in presuming this is a regular right hand thread on the axel nut. If so I would like to kill the guy that over tightened the nut. I am scared the tee bar will snap. The nut was put on with an impact gun? If so you more than likley need one to take it off. Also if it hasnt been off for a while try using PB Blaster on it that stuff works great on tough nuts. One more thing try tapping it with a hammer. Hopefully it wasnt crossthreaded . Goodluck Link to comment Share on other sites More sharing options...
tcspeer Posted August 27, 2005 Share Posted August 27, 2005 If you have a Harbor Freight store near you they sell a Giant 1/2 in breaker bar get it and use the pipe you have and P.B. blaster as suggested and it will come off. Link to comment Share on other sites More sharing options...
mattocs Posted August 27, 2005 Share Posted August 27, 2005 I broke three ratchets getting mine off. They were all 3/8 inch drive, and I was using an adapter with the large socket. I ended up getting a 1/2 inch drive ratchet and a pipe to get it off. Its tough...but it comes off. Link to comment Share on other sites More sharing options...
gbianchi Posted August 27, 2005 Share Posted August 27, 2005 I had to use a chisel and BIG hammer to get mine off, arrrg Link to comment Share on other sites More sharing options...
NorthLight Posted August 27, 2005 Share Posted August 27, 2005 You will need a replacement nut, as you will mung the crap out of the one you take off. Mine, we used a dremel to un-peen the castle nut. Given that I was replacing the front right half-axle, and it came with a new nut, I was good to go. PB blaster, torch, and an electric impact wrench finally got it loose. Link to comment Share on other sites More sharing options...
itzik93 Posted August 27, 2005 Share Posted August 27, 2005 There is a simple and easy way to do it, and you need for that GOOD TOOLS. Im using "Profexene" 1/2" SET and its wonderful. I bought a rod with an 1/2" adapter. Its exactly like 1/2" ratchet but without the ratchet. I put *1 meter* pipe on it and turn it counter clockwise. This way you are multyplying your hand torque very easy (its also good to open the crankshaft pully nut) Piece of cake... Itzik Link to comment Share on other sites More sharing options...
q240z Posted August 27, 2005 Share Posted August 27, 2005 Yup, Harbor Freight's the way to go. $10 or so will get you a tough 3' breaker bar. Put it on and stand on the end of it. Use the pipe if you have to, but don't break your back trying to lift it, ferchrissakes. Link to comment Share on other sites More sharing options...
frag Posted August 27, 2005 Share Posted August 27, 2005 There is a simple and easy way to do it, and you need for that GOOD TOOLS. Im using "Profexene" 1/2" SET and its wonderful. I bought a rod with an 1/2" adapter. Its exactly like 1/2" ratchet but without the ratchet. I put *1 meter* pipe on it and turn it counter clockwise. This way you are multyplying your hand torque very easy (its also good to open the crankshaft pully nut) Piece of cake... Itzik How about a little icing on that cake for good measure ? :-p Link to comment Share on other sites More sharing options...
rubysubaru Posted September 17, 2005 Author Share Posted September 17, 2005 I finally went to a garage and they could not get it off either using there most powerfull impact wrench. They suggested I cut it off. I went home and first drilled holes on opposite ends of the nut then finished one side with a carbide dremel tip. Smaked it with a chisel and it came off. At least I felt good that I was trying to take it off origanally as if it was a right hand thread, which it was. Now I am going to finish the job. Thanks All!!! Link to comment Share on other sites More sharing options...
dpoppeli Posted September 18, 2005 Share Posted September 18, 2005 Well it appears you solved it. I remember having to go to a garage for the same reason but I went to a truck garage... BIG impacts!. Just recently had a hitch put on by a private trailer shop and the guy there said his trick with commonly stuck undercarriage bolts/nuts was a blast with a torch and then a squirt of windex to rapidly cool it... wa-la (and I suppose you might even upgrade that nut due to case hardening at the same time). I finally went to a garage and they could not get it off either using there most powerfull impact wrench. They suggested I cut it off. I went home and first drilled holes on opposite ends of the nut then finished one side with a carbide dremel tip. Smaked it with a chisel and it came off. At least I felt good that I was trying to take it off origanally as if it was a right hand thread, which it was. Now I am going to finish the job. Thanks All!!! Link to comment Share on other sites More sharing options...
DaveT Posted September 18, 2005 Share Posted September 18, 2005 > I also just broke my Craftsman tee bar using the six foot pipe. I use a 3/4" drive breaker bar with whatever piece of pipe is handy *if* needed. A breaker bar is much stronger than a ratchet. Go to an industrial tool supply catalog like MSCdirect.com, coastal tool, Mcmaster Carr. Dave Link to comment Share on other sites More sharing options...
subie94 Posted September 18, 2005 Share Posted September 18, 2005 >I use a 3/4" drive breaker bar with whatever piece of pipe is handy *if* needed. A breaker bar is much stronger than a ratchet. i'd use a 1/2" drive breaker bar.but of course i've broken those too. Link to comment Share on other sites More sharing options...
