Do I have Hill Holder?
When on an incline with clutch in, press the brakes almost all the way in. Take your foot off the brake and the clutch should hold your place. Neat feature, don't know how to adjust it though. Also, I think it only works on an incline, not a decline.
You would adjust it the same way you adjust the cluctch. ON the back side of the clutch fork is a cable that goes to your brake cylinder. Just loosen it or tighten it as needed. The Hill Holder cable is opposite the Clutch cable. So you may need to tweak the Clutch adjustment as well- not sure Thanks
