WJM Posted August 29, 2005 Share Posted August 29, 2005 The RX is ready for SCCA National events now. Next step....air/water intercooler, Koni inserts, and some new seats. Then...roll bar. Link to comment Share on other sites More sharing options...
jkipina Posted August 29, 2005 Share Posted August 29, 2005 Did you use the Celica Water-Air intercooler? I just installed one in my Leone Turbo Link to comment Share on other sites More sharing options...
gravelRX Posted August 29, 2005 Share Posted August 29, 2005 That's got to be like 100hp worth of stickers. That one, a rotary one and a plain jane. that should be an interesting time. Jay Link to comment Share on other sites More sharing options...
nkx Posted August 29, 2005 Share Posted August 29, 2005 that looks fantastic! nicer than before that tree jumped out in front of you:drunk: i wish i had the time and materials to fix the buggy up nice as fast as you fixed your rx. Link to comment Share on other sites More sharing options...
tizzle Posted August 29, 2005 Share Posted August 29, 2005 Quote The RX is ready for SCCA National events now. Sweet! good to hear Link to comment Share on other sites More sharing options...
Warp3 Posted August 29, 2005 Share Posted August 29, 2005 You mean "ready" as in "ready to get owned by EJ powa", right Will!? :-p :burnout: Link to comment Share on other sites More sharing options...
gravelRX Posted August 30, 2005 Share Posted August 30, 2005 Now I was good-heartedly picking. That my friend is an all out. call out. If this were say, the 18th century, you would have a glove imprint on your cheek. Jay Link to comment Share on other sites More sharing options...
WJM Posted August 30, 2005 Author Share Posted August 30, 2005 Warp3 said: You mean "ready" as in "ready to get owned by EJ powa", right Will!? :-p :burnout: you better be prepared to get p2n3d by not one, but TWO white RXs. Link to comment Share on other sites More sharing options...
Warp3 Posted August 30, 2005 Share Posted August 30, 2005 gravelRX said: Now I was good-heartedly picking. That my friend is an all out. call out. If this were say, the 18th century, you would have a glove imprint on your cheek. Yeah, but autocross is always more fun when you smack talk first! Actually, I've yet to run against his RX when it was in top form (it was always vs him in the GL-10 or vs him codriving my own car ), but he did have some impressive finishes with it when it was fully prepped (I just wish it could have coincided with me actually attending those events as well). The RS vs RX battle should be very interesting. Flywheel estimates put my RS (cams, exhaust and a flywheel is all I have for "power mods" at the moment, most of my mods are suspension related) close to 200hp/210lb-ft and with an unbelievably flat torque curve, but even though my car is relatively light (mid-2700s in race trim) he most definitely has the weight advantage and he should be making at least similar (if not greater) peak hp numbers. I should have more cornering grip than him, though, unless he suddenly gets ahold of some grippier, wider tires (I'm on 225/50-15 V710s (and very new V710s at that) at the moment). Link to comment Share on other sites More sharing options...
WJM Posted August 30, 2005 Author Share Posted August 30, 2005 indeed...the smack talk is most normal for the NASIOC-SE peeps into the autox scene.... I will be on 13x5 rims with 215/50/13 Ecsta V700's on them at autox tread depth that are aproaching a year old now...so shane definatly has the physical tire grip advantage.... weight, I do have him. 2600~2615 is how much the RX weighs in at witha full tank of fuel. our spring rates are similar...but Shane has the advantage of Koni inserts, as I am on worn out KYBs. as for suspension bushings..i dont know what shane has, but I have full polyurethane... I have more camber and castor too! then it comes down to driver...im sure we will swap cars for a few runs to see what is what... Link to comment Share on other sites More sharing options...
Warp3 Posted August 30, 2005 Share Posted August 30, 2005 WJM said: our spring rates are similar... Which means mine are too low then...LOL. Of course, from what I've read 350-400 lbs is about the max spring rate that the off-the-shelf Konis will handle (I'm running 350 lb 8" springs (Ground Control setup) front and rear), so any more would require getting the Konis revalved. I am seriously tempted to go to a much higher spring rate next season and send the Konis off to get revalved to match (especially now that I have the 00LGT as a daily driver). Quote as for suspension bushings..i dont know what shane has, but I have full polyurethane... The Whiteline swaybars I have installed have poly bushings and the top mounts consist of bushingless camber/castor plates in the front and STi group N mounts in the rear. All the remaining suspension bushings are stock, though. Quote I have more camber and castor too! Camber, probably, but I do have a good bit of castor on this thing. I need to get an alignment done, so I have the exact numbers to compare. Quote then it comes down to driver...im sure we will swap cars for a few runs to see what is what... Well lately, you haven't been able to keep up with me driving my car, but you've been known to lay down some really fast runs in both cars, so I guess we'll see when the time comes. Link to comment Share on other sites More sharing options...
WJM Posted August 30, 2005 Author Share Posted August 30, 2005 yes indeedy. Link to comment Share on other sites More sharing options...
Subaru_dude Posted August 30, 2005 Share Posted August 30, 2005 that is the finest piece of machinery i've seen all day, and I work at a Dodge dealership and I see plenty of Vipers. Link to comment Share on other sites More sharing options...
Numbchux Posted August 31, 2005 Share Posted August 31, 2005 Subaru_dude said: I work at a Dodge dealership I'm sorry....:-p agreed, however, it IS gorgeous!!! Link to comment Share on other sites More sharing options...
