WJM Posted September 1, 2005 Share Posted September 1, 2005 So... I stretched the spring on one...+5psi I resealed and stretched the spring on another...installed it tonight...+15 psi....and NO aeration so no more HVLA ticking(old mickey mouse/pig on a bike gasket was BRITTLE and broken in several places). However...i still want more. Its got aobut 50~55 at warm up, ~15 at idle when warm...and ~40 at cruise when warm. EJ's have right at 100 cold...60~80 cruise warm...and ~40 idle warm. How so? New stuff me thinks.... So...worth it to sink $150 into a new pump? Edit: I am running Motul 5w30 8100...100% Synthetic. Quote Link to comment Share on other sites More sharing options...
JWX Posted September 1, 2005 Share Posted September 1, 2005 pull the oil relief springs out of the cam cases and strech them out. Quote Link to comment Share on other sites More sharing options...
Ross Posted September 1, 2005 Share Posted September 1, 2005 So... I stretched the spring on one...+5psi I resealed and stretched the spring on another...installed it tonight...+15 psi....and NO aeration so no more HVLA ticking(old mickey mouse/pig on a bike gasket was BRITTLE and broken in several places). However...i still want more. Its got aobut 50~55 at warm up, ~15 at idle when warm...and ~40 at cruise when warm. EJ's have right at 100 cold...60~80 cruise warm...and ~40 idle warm. How so? New stuff me thinks.... So...worth it to sink $150 into a new pump? New engines often have smaller clearances in engine bearings etc, giving higher oil pressure than older cars with the same oil. My ea81 (320,000km) is around 75psi cold, 50psi cruise and 20psi warm idle. Thats with 20w40 oil though, you may be running thinner? I wouldn't be too worried about those numbers, as long as it doesn't drop below 10psi no damage should occur. Quote Link to comment Share on other sites More sharing options...
WJM Posted September 1, 2005 Author Share Posted September 1, 2005 i see. IM running 5w30 Motul 8100 synthetic. Quote Link to comment Share on other sites More sharing options...
Ross Posted September 1, 2005 Share Posted September 1, 2005 i see. IM running 5w30 Motul 8100 synthetic. I'd say that your oil pressure is pretty good for that thin an oil then. My ea81t used to sit at around 20psi at warm cruise before a rebuild. Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 1, 2005 Share Posted September 1, 2005 i am using amsoil 10-w 30 and it gave me 5-10 more pounds of oil pressure Quote Link to comment Share on other sites More sharing options...
Bubonik Posted September 1, 2005 Share Posted September 1, 2005 does anyone know how these numbers translate to a canuk car ? mine says 0-3-6 low-mid-max where should it be sitting at idle ? mine is right around 3 at cruise and just below 1 at idle is this to low ? its much better than it was before the pump replacement !! Quote Link to comment Share on other sites More sharing options...
WJM Posted September 1, 2005 Author Share Posted September 1, 2005 that woudl be in BAR....aka metric measurement. 1 bar is 14.7PSI...2 is 29.4...3 is 44.1...6 is 88.2 Quote Link to comment Share on other sites More sharing options...
Vanislru Posted September 1, 2005 Share Posted September 1, 2005 does anyone know how these numbers translate to a canuk car ? mine says 0-3-6 low-mid-max where should it be sitting at idle ? mine is right around 3 at cruise and just below 1 at idle is this to low ? its much better than it was before the pump replacement !! Idle seems a bit low, I'm between 1 and 3 at idle and just under 6 at cruise[3500 rpm], but that's with 15/50 synthetic. Quote Link to comment Share on other sites More sharing options...
jeffast Posted September 2, 2005 Share Posted September 2, 2005 my gauge just sits at zero does any one know if i can pull the pressure sensor of any other cars i know it is the sensor because it went out after my upper raditor hose got a small leak and "peed" on it for a few hrs and i had to drive home etc my car is an 89 xt-6 er27 Quote Link to comment Share on other sites More sharing options...
wesley willis Posted September 3, 2005 Share Posted September 3, 2005 strange, my speedo reads in km/h but my oil pressure gauge reads in psi. Quote Link to comment Share on other sites More sharing options...
