yewman Posted September 29, 2005 Share Posted September 29, 2005 Someone here in the uk is selling "ametech Engine Restore Oil " at £40 ($70 ) a go. There are all sorts of claims about restoring worn engines back to standard and other impossible stuff . It sounds like a U.S. product .. Has anyone checked it out?? At that price it would have to be good . What's the miracle oil about? Regards Yewman. Link to comment Share on other sites More sharing options...
Storydude1 Posted September 29, 2005 Share Posted September 29, 2005 How long does it usually take for the MMO to free up a noisy lifter? On the engine I repaired we ran MMO in it for a couple of hours without results. . . Granted I did put in a quart when I changed the oil, and it got quieter over time as the engine ran (to warm it up and get the proper level on all of the lash adjusters). Perhaps it is a degree of "stuckness" that was the issue here. . . There may have been a couple of HLAs that were just starting to stick on the left and the MMO cleared them up when running with the new oil and MMO mix. . . Usually, 500-1500 miles. I put a 1/2 quart in EVERYTHING I own, once every 3rd oil change. No worries about loud valvetrains, or sludge buildup. MMO is a GREAT substance..Air tool oil, Bar and Chain oil, penetrant, works like Seafoam too if you are VERY careful about pulling it in. Link to comment Share on other sites More sharing options...
cookie Posted September 30, 2005 Share Posted September 30, 2005 but it only works if the lifters are not stuck very badly or worn. I would not add it to a good running engine as I don't believe diluting the oil is a good idea. Each to his own and whatever floats your boat. Link to comment Share on other sites More sharing options...
