Lawsonmh15 Posted September 3, 2005 Share Posted September 3, 2005 Doing a coolant flush today, and I'm wondering what standards to stick to when looking for a joint to do the flush. I've heard Subie coolant is a bit diff. than the run of the mill. I know ALOT of people swear by Mobil 1... What brand for coolant? Immediate answers are greatly appreciated. Link to comment Share on other sites More sharing options...
Setright Posted September 3, 2005 Share Posted September 3, 2005 I have had good results using Shell's pre-mixed 50/50 solution. Castrol doesn't seem to last - had a lab tech analyse it cause it was loosing colour and it was turning acidic after only a few thousand miles. Be aware that you MUST stick with the glycol based stuff, which usually means green or blue. Red and orange has a different base and will sludge up when mixed with the old coolant. Link to comment Share on other sites More sharing options...
Lawsonmh15 Posted September 3, 2005 Author Share Posted September 3, 2005 I have had good results using Shell's pre-mixed 50/50 solution. Castrol doesn't seem to last - had a lab tech analyse it cause it was loosing colour and it was turning acidic after only a few thousand miles. Be aware that you MUST stick with the glycol based stuff, which usually means green or blue. Red and orange has a different base and will sludge up when mixed with the old coolant. Thanks for the advice. I went to a local indie joint that wanted $60 but the coolant had no brand (no thanks:rolleyes:). Kid told me it was "The green kind". I proceeded to Grease Monkey. They wanted $70 for prestone EG. No conditioner though. After having done a search over at the NASIOC, I found a SWEET thread on the importance of a good coolant and conditioner, and problems that may result from ignorance. Check it out. http://forums.nasioc.com/forums/showthread.php?t=504002&highlight=Radiator+Flush I remembered that John Elway Subaru South was down the street and I went there because neither of the places had a conditioner. It was only $1.29. The service dept. didn't seem busy so inquired as to how much a coolant flush was. $50:banana:. SOLD. I also picked up an external tranny filter. However, it took them close to 2 hours to do the service (will schedule next time). But the service manager gave me $10 off the flush, and $10 off the tranny filter . These guys honor ANY competitors coupons!!! The have gotten coupons for $5 oil changes and taken the hit on it. I couldn't believe it. I will be frequenting that joint for ANY service issues. Almost forgot. Before having the flush and condioner, my fans were kicking on after about 30-45 seconds of idling. After... I idled for about 5 mins before I got bored and shut her down. COULDN'T believe it. Link to comment Share on other sites More sharing options...
