Ratty2Austin Posted September 5, 2005 Share Posted September 5, 2005 yesterday in the minneapolis area, it poured the rain out like crazy! thunderstorms and flash flood warnings on the news... so i went puddle splashing! tonight on the way to the grocerey store, I came across a flodded road, and decided to take the impreza across it as fast as I could (accelerating from the point at wich i discovered it, so it was only about 35mph) and then I went back and did it again... the second time thru though, it must have sucked up some water because it slowed way down and the CEL came on it was blinking on and off a bunch, and the motor did not want to run when i was holding down the gas. it would idle just fine though, so it wasnt flooded completely- when i got to the apartment, i took the air filter out and it was completely soaked! so I think its time for the snorkel treatment, and a splash guard/skid plate to cover the bottom of the engine bay.... any of you MN guys want to help me out, with at least an idea of where I can get some of the needed things ( skid plate material? ) or where to get a good deal on parts for a snorkel (ABS/PVC pipe or drainage hose?) pics of the impreza's recent offroad mods to come soon too and.. I am still looking for a PS rack!! Link to comment Share on other sites More sharing options...
MorganM Posted September 5, 2005 Share Posted September 5, 2005 Sure thing Austin. For steel I'd suggest Discount Steel up on Washington Ave. in Minneapolis. They have a 'scrap' selection that cant be beat. They also have anything else you would ever need in stock but prices are higher if it's not a 'scrap' piece. Home Depot should have all the snorkel materials you need. Maybe we can get together and hit up a HOme Depot. I should put a small snorkel on mine also. My current airbox setup works well but its rather ghetto fabulouse Link to comment Share on other sites More sharing options...
Freddie Posted September 5, 2005 Share Posted September 5, 2005 MorganM said: Maybe we can get together and hit up a HOme Depot. I should put a small snorkel on mine also. My current airbox setup works well but its rather ghetto fabulouse (Austin using Freddie's computer) cool! sounds like one of these weekends we should have a snorkel install day! (and skid plate) Link to comment Share on other sites More sharing options...
Kostamojen Posted September 5, 2005 Share Posted September 5, 2005 Having that MAF in your intake on your '94 makes it a bit harder to fab a snorkel I would think... You might have to get some 3" tubing and some silcone connectors and try to route it closer to the firewall then have it go up either through a hole in the hood or through the firewall up the side of the window through the cowl area. Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted September 6, 2005 Share Posted September 6, 2005 just follow the fender well to the upper back corner of the fender, works like a charm, at least mine did....... Link to comment Share on other sites More sharing options...
tailgatewagon Posted September 7, 2005 Share Posted September 7, 2005 stearing rack huh. like from an outback sport with a 1.8 in it? i think i know where one is. ill check on it tomrrow. let me know what you want to pay and ill see if the guy will sell it for that(still in car) i guess i can pull it for you. anyway let me know. Link to comment Share on other sites More sharing options...
