Bucky92 Posted September 5, 2005 Share Posted September 5, 2005 For those who are planning on coming to my place on the 24th to help fix my Loyale..I need a list of parts you all feel like I need. I am figuring: New timing belts valve cover gaskets oil pan gasket cam seals oil pump gasket alt and fan belts clutch kit and flywheel ( Already have a line on these..Thanks KingBobDole) throw-out bearing Anything else or anything I need a reminder not to forget??? Thanks All Link to comment Share on other sites More sharing options...
subyrally Posted September 6, 2005 Share Posted September 6, 2005 a can of sea foam. the greatest thing ever made for cars. Link to comment Share on other sites More sharing options...
subeman90 Posted September 6, 2005 Share Posted September 6, 2005 bolt gaskets for on the valve covers Corn? maybe a new toilet flusher? Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted September 6, 2005 Share Posted September 6, 2005 New timing belts valve cover gaskets oil pan gasket cam seals oil pump gasket alt and fan belts clutch kit and flywheel ( Already have a line on these..Thanks KingBobDole) throw-out bearing water pump? cam shaft housing to cylinder head O ring? Front and rear crank shaft seals? Timing belt tensioners? Oil filter? (and oil) radiator cap? (always a good idea if it's never been replaced) Oil pickup O ring? Hydraulic lash adjuster relief springs? Head gaskets? (if you wanna risk breaking an intake manifold bolt, been there done that ;-) O2 sensor? Pilot bearing? Cap and rotor? Timing belt cover seals? (Connie should run Bucky's belts naked! ;-) water pipe O ring? water pump gasket? Fuel filter? damn and I haven't even started on anything not on the engine.. Missing anything..? Link to comment Share on other sites More sharing options...
Turbone Posted September 6, 2005 Share Posted September 6, 2005 Timing belt cover seals? Eh? Do they sell these on the Is. only? I dont think she can afford everything you listed, but it would sure be nice if you donated some Link to comment Share on other sites More sharing options...
Bucky92 Posted September 6, 2005 Author Share Posted September 6, 2005 New timing beltsvalve cover gaskets oil pan gasket cam seals oil pump gasket alt and fan belts clutch kit and flywheel ( Already have a line on these..Thanks KingBobDole) throw-out bearing water pump? cam shaft housing to cylinder head O ring? Front and rear crank shaft seals? Timing belt tensioners? Oil filter? (and oil) radiator cap? (always a good idea if it's never been replaced) Oil pickup O ring? Hydraulic lash adjuster relief springs? Head gaskets? (if you wanna risk breaking an intake manifold bolt, been there done that ;-) O2 sensor? Pilot bearing? Cap and rotor? Timing belt cover seals? (Connie should run Bucky's belts naked! ;-) water pipe O ring? water pump gasket? Fuel filter? damn and I haven't even started on anything not on the engine.. Missing anything..? Ummmmm we arent rebuilding the motor:grin: from the talk they are just going to pop out my motor to make some stuff easier (clutch) . I dont need to do anything with my heads...I do not have a head gasket leak..Buckys motor is good and strong..ticks alittle but not bad enough to worry about anything with my HLAs..Also water pump is good why fix it (plus I have a spare or 2 lying around). plugs cap rotor....all dont about 2 months ago Now the tensioners..thats what I was trying to remember Thanks Link to comment Share on other sites More sharing options...
subeman90 Posted September 6, 2005 Share Posted September 6, 2005 there was some guy selling a t-belt set and tensioners on ebay as a package...might want to take a min and look on there. I believe it was $64. Link to comment Share on other sites More sharing options...
edrach Posted September 6, 2005 Share Posted September 6, 2005 Only reason to replace the water pump is to avoid the cost of labor in doing it later. My rule of thumb on the EA82s has been to do the timing belts every 60K miles and the water pump every other timing belt change since the water pump is not likely to last 180K miles. Definitely change the tensioners too. While I'm at it, I definitely recommend www.1stsubaruparts.com; best prices around for genuine Subaru parts. Easier to call their 800# and ask for Jason in parts rather than negotiating the website. Good luck with the repairs. Link to comment Share on other sites More sharing options...
