redbeagler7 Posted September 6, 2005 Share Posted September 6, 2005 I just bought a 86 DL 4 door sedan which needs rear brakes and wheel bearings. The problem is I can not find the new lock washers for the axle nut any help would be welcomed. Link to comment Share on other sites More sharing options...
86subaru Posted September 6, 2005 Share Posted September 6, 2005 welcome to the board , i am also from ohio [ western part] were did you get the special tool , to remove bearing ? Link to comment Share on other sites More sharing options...
subarunuts Posted September 6, 2005 Share Posted September 6, 2005 4WD or 2WD? They are very different. No special tools are required for either type. There is a socket for the 4WD rear bearing retainer ring, but a punch works fine generally. Link to comment Share on other sites More sharing options...
KStretch55 Posted September 6, 2005 Share Posted September 6, 2005 86Sub, get a 1 1/4" 4 prong socket (used on Ford 4X4 front wheels) at Schucks for $14. Grind off two of the prongs and leave two on opposite sides. Works great for those rear wheels on 4x4 Soobs. I need to get some of the lock washers before I tear mine apart the next time, too. I hope the stealership isn't the only place they're available. I can only imagine what they want for them!!! Link to comment Share on other sites More sharing options...
