jeffast Posted September 6, 2005 Share Posted September 6, 2005 the prevouse owner took out the air suspension and the air lines and the wiring??? i know that is bizarre i am wondering what other cars have the bolt pattren, length, to fit both front and back incase any one asks that Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 6, 2005 Share Posted September 6, 2005 EA82 rear shocks and any aftermarket stuff for them. Legacy front struts, with the same as above. I think Imp struts will work on the front also, but you need to swap hubs to do it. Quote Link to comment Share on other sites More sharing options...
jeffast Posted September 7, 2005 Author Share Posted September 7, 2005 thanks Quote Link to comment Share on other sites More sharing options...
bulwnkl Posted September 8, 2005 Share Posted September 8, 2005 No need to swap hubs to use Impreza fronts. You will have to shave the lower mount on the hub or else spread the lower mount on the strut a little. It's not a big deal to do it at all. I have '01 2.5RS Impreza struts and springs on the front of my '91 XT6. They work very well. Drill the lower mount holes and use the mount bolts from the Impreza so you have camber adjustment/control. Quote Link to comment Share on other sites More sharing options...
