Blue84Hatch Posted September 6, 2005 Share Posted September 6, 2005 Are there only certan EJ22s that are able to be swapped into EA81s? Will a 1998 EJ22 from an Impreza work with the EJ to EA adapter plates made for the swap?? Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 15, 2005 Share Posted September 15, 2005 the benifit of the older EJ22's is that they don't require a vehicle speed sensor, which makes the swap infinately easier. Link to comment Share on other sites More sharing options...
yegoshin Posted September 15, 2005 Share Posted September 15, 2005 hmmm i got mine out of a 95 legacy I think that does have the speed sensor, What are your suggestions about that? Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 15, 2005 Share Posted September 15, 2005 95 may be ok, because its pre OBD II, but it may not be as good, don't know 100% Link to comment Share on other sites More sharing options...
Snowman Posted September 15, 2005 Share Posted September 15, 2005 hmmm i got mine out of a 95 legacy I think that does have the speed sensor, What are your suggestions about that? I think Noah may be correct. The guy I got my EJ22 from said that when they went to the newer computer setup around that year, the vehicle would go into a derated "limp-home" mode if any of the sensors were not hooked up. I'm not sure if it happened in 95 or 96, but I assume the change would coincide with going to OBDII. According to my FSMs, the speed sensor voltage ranges are not compatible between the EA and EJ cars. The EJ22 computer needs a pulse that goes between 0 and 5 volts, and the EA82 computer needs an input that varies slightly above and below 2 volts. I was not able to find the spec for the EA81, but it should be the same as the EA82. My EJ22 seems to have no trouble running without a VSS. (It's an 89 engine with the harness and ECM from a 92.) Link to comment Share on other sites More sharing options...
yegoshin Posted September 15, 2005 Share Posted September 15, 2005 pretty sure my is OBD II because the legacy harness had the OBDII connector as well as 2 oxigen sensors. Link to comment Share on other sites More sharing options...
Snowman Posted September 15, 2005 Share Posted September 15, 2005 What is the production date of your engine? I just called a friend of mine who knows the EJ computers like the back of his hand and he needs to know that before he can look into it. He did say you probably do need the VSS, but that it's likely you could take the VSS pickup out of the legacy tranny and put it in your d/r. Link to comment Share on other sites More sharing options...
Blue84Hatch Posted September 15, 2005 Author Share Posted September 15, 2005 It is an EJ22 out of a 1997 Impreza L. I will only be getting the complete engine but only the engine harness, and thats it. This leaves me with obtaining and ECU and body harness. I hope that this engine will work. It ran like a beast in that lil Impreza and just know it will pep up the hatch great. Link to comment Share on other sites More sharing options...
Blue84Hatch Posted September 20, 2005 Author Share Posted September 20, 2005 any update if this engine is worth using for a swap or not??? Link to comment Share on other sites More sharing options...
Snowman Posted September 20, 2005 Share Posted September 20, 2005 Since you have to find an ECM and harness anyway, you might check and see if you could run the 97 engine with the computer from an older car (90-94). The stuff on the engine itself could be exactly the same and plug right in. The guy that I mentioned earlier said that he ran an EJ25 (which I believe didn't come out until after the OBDII switch) with the computer and stuff from an earlier EJ22 in a vanagon conversion he did a while ago. I'll give him a ring tomorrow and see if he found out anything yet about your engine. You should be able to use it regardless. It may just take a little research and fabrication. Link to comment Share on other sites More sharing options...
Blue84Hatch Posted September 21, 2005 Author Share Posted September 21, 2005 The impreza that this engine came out of got a 2.5 to replace it. It is my buddies impreza and he is using the 2.2 ECU that was in the impreza to run the 2.5 and it works perfect. So I could get either a 2.5 or 2.2 for this one I bet. I am just wondering what the years were that were compatible with other years. That is as far as sensors. I was mostly wondering about the adapter plate kit that they make for the EJ22s to bolt to dual range trannies. And that this one will be compatibale with the adapter plate kit. Link to comment Share on other sites More sharing options...
Snowman Posted September 21, 2005 Share Posted September 21, 2005 As far as I know, the adapter plate will allow ANY EJ engine to bolt up to ANY EA82 transmission. I don't think the engines went through any changes that would cause them to not physically bolt up. Link to comment Share on other sites More sharing options...
ShawnW Posted September 21, 2005 Share Posted September 21, 2005 The downside to that engine is its the interference model. I would hold out for a 90-94 myself. Link to comment Share on other sites More sharing options...
