SUBARU3 Posted September 7, 2005 Share Posted September 7, 2005 What would cause "hunting" between 2nd-3rd shift. The trans is fine otherwise. 80K AWD. If you floor it, it shifts through all gears fine. Under normal acceleration, it shifts 1-2 OK and then 2-3 feels like it goes to 4th for a sec and then back to 3rd. Then shifts to 4th normally as speed increases. Torque converter lock up is ok too. Downshifts are fine also. Ideas? Thanks, Todd Link to comment Share on other sites More sharing options...
langosta39 Posted September 7, 2005 Share Posted September 7, 2005 My 95 Legacy does this if I have the gear selector in "3", but it has never done it in "D". Even then it only seems to do it when accelerating brisky in 2nd and then pulling off the throttle. Its like the car wants to double shift because of no load but then realizes its supposed to be in 3rd instead of 4th. Its done it for 10,000s of miles and never a problem, but I do know that it needs a fluid flush (chattering when turning hard in 1st gear). Andy Link to comment Share on other sites More sharing options...
RallyKeith Posted September 7, 2005 Share Posted September 7, 2005 What would cause "hunting" between 2nd-3rd shift. The trans is fine otherwise. 80K AWD. If you floor it, it shifts through all gears fine. Under normal acceleration, it shifts 1-2 OK and then 2-3 feels like it goes to 4th for a sec and then back to 3rd. Then shifts to 4th normally as speed increases. Torque converter lock up is ok too. Downshifts are fine also. Ideas? Thanks, Todd Can you answer a few questions for me: What year is the car? Does it do it only when cold? Does it do it only when hot? Does it do it all the time? Have you ever had the fluid changed, if so when? The answers to these may give us some better insight. Keith Link to comment Share on other sites More sharing options...
idosubaru Posted September 7, 2005 Share Posted September 7, 2005 ever changed the ATF? might be a good place to start at 80k you're due anyway. with a minor symptom, changing the ATF might help. on the passengers side strut tower there's a shift resistor on some 4EAT's (maybe all, i don't know). i disconnect mine for firmer and quicker shifts. i'd unplug yours to see if it makes any difference in shifting. if your glitch went away after unplugging then maybe that shift resistor is bad. i doubt this is the problem, but since it literally takes like 13 seconds to try it doesn't hurt. better than starting with complicated diagnosis. shift kits bypass this resistor under certain circumstances...unplugging it basically does the same thing except you don't give someone else your money. Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 7, 2005 Author Share Posted September 7, 2005 Can you answer a few questions for me:What year is the car? Does it do it only when cold? Does it do it only when hot? Does it do it all the time? Have you ever had the fluid changed, if so when? The answers to these may give us some better insight. Keith The car is a 95 /awd It does it all the time cold or hot. However sometimes it seems OK, but generally, it consistently happens. Yes, I have changed the fluid at frequent intervals. It does seem like it started AFTER a fluid change. Fluid quality issue maybe?? I'l also try that resistor. Link to comment Share on other sites More sharing options...
RallyKeith Posted September 7, 2005 Share Posted September 7, 2005 The car is a 95 /awdIt does it all the time cold or hot. However sometimes it seems OK, but generally, it consistently happens. Yes, I have changed the fluid at frequent intervals. It does seem like it started AFTER a fluid change. Fluid quality issue maybe?? I'l also try that resistor. I'm thinking it could be a fluid level or quality issue. At higher RPMs, like would be seen under full throtle shifting, you will be building more pressure from the pump in the trans. I don't know for sure but it could be that for some reasons it doesn't have enough pressure to sharply engage the gear. I guess check the fluid level for a start. There is a specific procedure in the owners manual for that. Keith Link to comment Share on other sites More sharing options...
ShawnW Posted September 7, 2005 Share Posted September 7, 2005 Fluid LEVEL is big on these. The symptoms sound like it has a quart or more too much fluid in it. Checking the fluid level is done by having the car at idle, and running the car thru each and every gear, pausing between each one, finally returning to Park and checking level. Link to comment Share on other sites More sharing options...
ShawnW Posted September 7, 2005 Share Posted September 7, 2005 but I do know that it needs a fluid flush (chattering when turning hard in 1st gear). Andy Sorry but thats not likely to be the fluid. More than likely an axle going or the front differential fluid needs changed. Link to comment Share on other sites More sharing options...
langosta39 Posted September 7, 2005 Share Posted September 7, 2005 Ive read many times, and was told by the dealer, that those symptoms are cured by a fluid flush and a friction modifier, but thanks for in the input. Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 8, 2005 Author Share Posted September 8, 2005 Well, it was not the resistor. I'm going to try a fluid change next. Todd Link to comment Share on other sites More sharing options...
