Sweden Posted September 7, 2005 Share Posted September 7, 2005 O.K. this is a new one. I need your help with some Swedish translation. My '96 OBW was in the shop for a check engine light problem. In the process, the mechanic stated that I needed to order and replace something that I translate to a cam axle sensor (kamaxel givare in Swedish). Is there something that goes by roughly this name? It was bad but easy to replace. Thanks! Sweden Link to comment Share on other sites More sharing options...
aceboxer Posted September 7, 2005 Share Posted September 7, 2005 Sweden said: O.K. this is a new one. I need your help with some Swedish translation. My '96 OBW was in the shop for a check engine light problem. In the process, the mechanic stated that I needed to order and replace something that I translate to a cam axle sensor (kamaxel givare in Swedish). Is there something that goes by roughly this name? It was bad but easy to replace. Thanks! Sweden Probably a cam angle sensor, that sounds close. This article may be of help: http://autorepair.about.com/library/ts/obd-i/bl-dtcs-78a.htm Link to comment Share on other sites More sharing options...
Setright Posted September 7, 2005 Share Posted September 7, 2005 Yessir, "givare" means to deliver, so that'll be the cam angle sensor. Surely this part is universal, so that you don't have to wait to get one from the states? Link to comment Share on other sites More sharing options...
Sweden Posted September 8, 2005 Author Share Posted September 8, 2005 Its the 'axel - angle' part that I am not totally certain on. Sweden Link to comment Share on other sites More sharing options...
Setright Posted September 8, 2005 Share Posted September 8, 2005 Ermmm, what do you mean? "kamaxel" means "camhaft" for sure. Link to comment Share on other sites More sharing options...
Sweden Posted September 9, 2005 Author Share Posted September 9, 2005 I will assume that they are the same and contact them here for a price. Thanks! By the way, I had a great time in Copenhagen last week. The problem was the 4-5 hrs of commuting each day. The bomb scare (forgotten backpack) was also a problem at Osterport. I didn't see any Imprezas flying down the road past me though... Link to comment Share on other sites More sharing options...
Setright Posted September 9, 2005 Share Posted September 9, 2005 Bad timing, since I was also caught up in the bomb scare blockage around Osterport. What are the odds? Link to comment Share on other sites More sharing options...
