How fast??
jmr052
I am after some speed/rpm numbers from an ea82 d/r.
At 3000 rpm how fast are you going in 4 Hi:
1st
2nd
3rd
4th
5th
At 3000 rpm how fast are you going in 4 Lo:
1st
2nd
3rd
4th
5th
Then I also need to know if you have a 3.7 or a 3.9 diff.
Thanks,
Jay
Well, I don't have any answers for you since mine isn't running at the moment, but I do have a question. Are you looking for the Turbo or the non-turbo version? I'm pretty sure that in the RX models they used a different ratio for the diffs so you would get different speeds from a non RX d/r.
Keith
But I cant recall ever needing to use any gear past 2nd when in 4LO, and I definately dont remember using 3000 RPM in any Lo range gear. I thought that if you could keep the engine above 2000 then you should be using hi range. Isn't that the point?
If I had 5 gears I'd tell you.:boohoo:
But my Subie has only 4/dr:boohoo:
I turn 3000 @ 55mph in 4th:boohoo: :boohoo: :boohoo:
For what it's worth
Glenn,
82 Hatch,........transforming...:temper:
01 Forester,....just plain fast!.:brow:
The point?? Well, that will have to be answered later!
Yes the RX D/R tranny has a different reduction ration ~1.2 and uses the 3.7 diff. I would really like to know if any of the trannies used the ~1.6 reduction w/ the 3.7 and the resulting speeds. I would also like to know the speeds for the 1.6 w/ 3.9 combination. If you don't want to "windup" the subie that far in low, I could use say a 2k rpm # instead but use the same # for Hi.
Come on now, 10 minutes and it's done.
Thanks,
Jay
It's just a reduction gear and I don't think it's a problem running to red line in low. I use mine all the time in the RX. I ran an entire rally cross using low range with 2nd and 3rd gears. It put the car in the right RPM range for max power coming out of turns. I sometime use it to pass on a back road instead of say downshifting all the way to third. Atleast in the RX it comes in handy for things other than creaping.
Keith
  • 2 years later...
I just swapped a dual range 3.90:1 in my '80 wagon with an EA71 from the origional(sp?) single range 4.11:1. I still haven't replaced my broken speedo cable for a few years, so I don't know how fast I'm going in whichever gear or range. But low range hauls a$$ uphill in third.
